Home > Maintenance & Modifications > Help with HID bulbs 4300K 6000K 8000K 10000K ??
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Hi can some one please advise me which HID bulb i need, What is the difference between the 4300K 6000K 8000K 10000K and are they all legal, Thanks Steve
Post #455589 Wed Mar 11 2015 10:33pm
sagalout
Go for 4300k for OEM look - the higher the number the bluer the light. 5000k is supposed to be the ideal
Post #455591 Wed Mar 11 2015 10:39pm
RonyTed
England 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Hi, the lower the number 4300k will give a yellow light, the higher the number 10000K will give a blue light. I have fitted 6000k which gives a crisp white light (this is about as high up the scale you can go and still stay legal) and looks good if you change the side lights to 6000K LEDS.
cheers,
Tony.
Post #455598 Wed Mar 11 2015 11:28pm
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Also remember that the higher you go, the less bright the lights will actually be. 4300k is meant to be the brightest AFAIK, 6000k will have a distinct blue tint to them (bought these for my old E30).. and once you get past about 12000k I think, maybe slightly higher, they actually start to change colour completely.. with purples, greens, etc.. just FWIW Smile
Personally I'd be after 5000k, 6000k as an alternative, but certainly no higher.
Maybe this will help a little Smile
Cheers..
Ian
Post #455603 Thu Mar 12 2015 12:43am
Lost for Words
If you want maximum light output, go for 4300k. 5000k if you must but 6000k will just be reducing the output. Thumbs Up Visiting from DISCO3.CO.UK
Post #455615 Thu Mar 12 2015 9:31am
stebenny
Thanks everyone for your help, I have gone for the 6000k ones they will be here monday so i will see what they look like, Thanks
Post #455916 Sun Mar 15 2015 11:53am
Russben
I'm sure I've seen you around so I'll keep an eye out for you & let you know how they look. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #455930 Sun Mar 15 2015 2:10pm
robertevans68
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Are there any updates on bulbs available? What do people fit to get the same colour/look of the headlights. I have a 57 reg sport and just want the sidelights to look the same, I don't want to go down the eBay route that only last a week!
Any recommendations appreciated
Thanks Rob
Post #479784 Sat Nov 14 2015 2:08pm
Lost for Words
I recommend these: http://www.hids4u.co.uk/501-led-bulb-long-...white.html I find the 5000k ones match the OEM (4300k) bulbs well. (Re xenon bulbs, my recommendation is as above.) Thumbs Up Visiting from DISCO3.CO.UK
Post #479786 Sat Nov 14 2015 2:22pm
robertevans68
Thanks I will take a look now.
Post #479805 Sat Nov 14 2015 5:59pm
