Home > Technical > Mis-fire at idle
Mslochab
Canada
Mis-fire at idle
Hey Guys.
So I have an issue. My 2007 tdv6 has been misfiring badly. So took it to a shop and they took the injectors out of the bench and tested and they are all fine.
So they did a few changes from another sport they had sitting in the shop to see if they could find the problem, but are unable to figure it out.
The car on idle misfires enough that it shakes. as soon as you touch the gas it goes away.
Car is located in Kenya, East Africa . Would appreciate any help
Post #455322 Mon Mar 09 2015 7:47pm
Bodsy
Site Sponsor
Oil temperature sensor. Probably reading -30. Can you read live values on it? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #455324 Mon Mar 09 2015 7:56pm
Disco_Mikey
They need to strip the injectors, and check the nozzles.
I suspect they will.be badly worn
Have been in a similar situation before Thumbs Up
Post #455335 Mon Mar 09 2015 9:03pm
Mslochab
Canada
we checked the injectors on the bench and they ran fine. never the less 6 new injectors and the same problem.
Shocked a real headache
Post #455402 Tue Mar 10 2015 10:53am
