Home > General > Crossing the battery leads
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi all, I've always had trouble with my Blackberry 9300 Curve syncing with the car, a 2007 TDV8. It does so about 10% of the time. Several of you have suggested I connect the battery leads (well away from the battery!) for 20 seconds or so. Before doing so, can anyone tell me what actually happens when you do this? The car is trouble free & I don't want to create trouble with anything like dash readouts etc!! Many thanks Thumbs Up
Post #455297 Mon Mar 09 2015 4:46pm
Bodsy
Site Sponsor
It's a hard reset. It will drain all the capacitors in the modules in the car and in turn, effectively remove their synced memory (for want of better words).
Next time the car starts, it should do it in order and with all modules from scratch.
It wont affect your mileage or dash readouts, it wont affect your radio stations, you will need to reset the clock. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #455298 Mon Mar 09 2015 4:49pm
Timf
Thanks Bodsy. I'll give it a go Very Happy
Post #455299 Mon Mar 09 2015 4:51pm
andynpz
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Bodsy, might that procedure work to eliminate a very intermittent ADAPTIVE DYNAMICS FAULT message? - comes up after start about once a month - always goes on restart. 2011 TDV6 HSE Stornoway grey, ivory trim
Life's too short to drive an ugly car.
Post #455350 Mon Mar 09 2015 10:13pm
Bodsy
Site Sponsor
I doubt it Andy, but it doesn't cost anything to try it. Make sure the battery is fully charged will also help Thumbs Up Bodsys Brake Bible
See it HERE
Post #455379 Tue Mar 10 2015 12:04am
