Home > Technical > b1d12-15 ranger rover sport
Rst13
Norway
Hello and thank you all for a great forum.......
I got a problem with my RRS 2006 my 2,7
All the lights are flashing in the dashboard and there is an E in the gearshift indicator.
On of the fault codes are b1d12-15 volumetric alarm power circuit.
Hazard is on when the ignition is on...
Any body?
Ronny
Post #455277 Mon Mar 09 2015 3:28pm
Lost for Words
Welcome. Thumbs Up
It sounds like you may have a CANBUS fault. Damaged wires in the wheel arches are a common cause of this so I would have a look there.
Can you give any more detail on the symptoms? Will the car start/drive? Question Visiting from DISCO3.CO.UK
Post #455283 Mon Mar 09 2015 4:03pm
Rst13
Norway
The car is not starting, and it has suspension, transferbox ++ faults.
Post #455304 Mon Mar 09 2015 5:13pm
Bodsy
Site Sponsor
sounds like it is in crash mode. You really need to give us the full picture....
what are the full codes, what are the other symptoms, what happened to cause the issue initially.Have you had any other work done on it recently...? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #455307 Mon Mar 09 2015 5:18pm
Rst13
Norway
It just was like this in the morning, no work done before it happend.
Fault codes:
B1a00-16
B1a99-c4
B1b02-28
B1c42-23
B1c57-14
B1d12-15
B1s14-15
U0155-87
See photos in the gallery
Post #455413 Tue Mar 10 2015 2:53pm
Rst13
Norway
Lost for Words wrote:
Welcome. Thumbs Up
No damage in the connection in the wheel arches
Post #455414 Tue Mar 10 2015 2:58pm
Disco_Mikey
Crash mode would clear with an ignition on/off Thumbs Up
You have, as stated previously, a CANBUS issue. The RRS seems very prone to CAN wiring issues under the back end of the car, and also the IPC. This is where I would be starting Thumbs Up
Post #455433 Tue Mar 10 2015 6:16pm
Rst13
Norway
Thank you, I'll start on that first time in the morning:)
Post #455434 Tue Mar 10 2015 6:27pm
Rst13
Norway
It was the canbus wiring in the left rear side, thank you so much for the help:)
Post #455563 Wed Mar 11 2015 4:47pm
Lost for Words
Glad to hear it's sorted. Thumbs Up Visiting from DISCO3.CO.UK
Post #455566 Wed Mar 11 2015 5:30pm
