![]() | Home > Orders (L494) > SVR in the Wild! |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
I guess the question now is "is the ipod doing the playing and sending an audio signal to the car or is the car reading the track from the ipod and playing from there?" I've never owned an ipod so I cannot comment. I use a 32gb Sandisk cruzer Fit that I just leave in the car its nice and small so it cannot get bashed about putting other stuff in the armrest.
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Or you could use your existing tablet/phone with unlimited data at £15 pm and use that as a wi fi hotspot anyway, which passengers could jump off if required? |
very true or you could pay to have a hot spot put in your car. |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Indeed there are and I added the option as much out of interest as real need.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690 ![]() ![]() ![]() |
OK, here's a question. When playing music stored on an iPod/iPhone, what is doing the decoding - the phone or the car? EDIT: Sorry - eddkawasaki asked the same. It must be the car, surely, as USB is, by definition, a digital bus. So does the 'Sport decode Apple Lossless, or just AAC (both different, both MPEG-4 .m4a files). I've tried and can't get lossless to work on my MY12 car. FLAC certainly won't, nor will ALAC, nor anything at 98 kbps. ![]() |
I think it's the car; all the clever Meridian processing needs to work on the digital data so the iPod is simply an external Mass Storage Device.
Correction: Lossless does work, but needs to be 48 kbps and 16 bit. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
48 Kbps? Seems rather low quality |
Yes, you're right. Should have said 48 KHz! |
It was slightly naïve to think that retro-fitting the drinks cooler was going to be plain sailing and so it's turned out.
Is that via an iPod or USB stick? |
That was via a stick as it was easier to load every format and see what plays. The iPod will only take the files it can play. |
That's great news I might be able to get rid of my MP3 library that I just keep for use in the car.
Car back, new number plate on straight without screws and drinks cooler neatly installed, all looks fine. They thoughtfully left a bottle of water in there. TPMS still working.
