![]() | Home > Maintenance & Modifications > Front Diff Pipe Vent Upgrade !! |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, just fitted my front diff vent pipe upgrade, 5 min job. The one I took off was solid as a rock, hopefully it has helped save the life of my diff, there was a slight smell of oil when I cut it off so something has been stuck in there, thanks for the tip boys |
Well done. To finish the job why not drain and refill the diffs? Useful guidance here: http://www.disco3.co.uk/forum/topic32281.html 2008 MY Java Black TDV8 HSE
Hi, thanks for that, wouldn't be a bad idea now to finish the job off |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Is this the upgrade you've done?
jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
Just added this upgrade to my list and ordered the part, thanks |
Hi, yes this is the one, I think for what it costs its a must. The one I cut off was solid and certainly not venting the diff ![]() |
Cheers - just ordered myself one too - a little job for next weekend |
Hi, unsure of the year but if you take a look you will see if it has the old one on or been upgraded, |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Cheers, will take a look later today, can't say I've ever noticed this vent, but then again never looked for it! 2010 RRS, TDV8
Its only small and something you wouldn't even notice unless told, but worth the upgrade I would say |
Your right there, looking at the pics it appears to be a large ish pipe but in reality it's quite small, no wonder I never noticed it. ( sounds like something my wife would say) |
lol, good man, I think it was around the £13,00 mark from Advanced Factors, delivered.. |
