![]() | Home > Orders (L494) > SVR Ordered! |
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
Dickie think you must be right there 2016 bmw x5 40d m-sport space grey
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 ![]() ![]() |
Anyone fancy phoning to ask? Guess it does rather depend on spec though. Mine is coming in at a fraction until £100k but my dealer has another order for one over £115k. SOLD - 15 plate Estoril SVR
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Yes, the options list is an exercise in (lack of) self-control. Of course it's down to personal choice and we'll each build our ideas of what's worth having and what's not.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690 ![]() ![]() ![]() |
I think the most one can get to without the dealer-fit accessories is just over £114k. Notice the leather on the rear seats |
Oh dear (rushes out to check his back seats). Mark
Pleased to say mine look fine...
pleased yours looks great Mark but the other cars look terrible not what you expect when your spending around 100k 2016 bmw x5 40d m-sport space grey
There's surprising sample variation and, as we've said before, you have to wonder at the quality control at Lear/Johnson Controls/whoever in letting that through and the same at Land Rover.
Hope things go smoothly tomorrow 2016 bmw x5 40d m-sport space grey
Thank you. Turns out the front number plate is mis-aligned too, flush with one edge of the backing plate and overlapping the other by 3mm. I'll probably let that one go. Mark
Predictably, the TPMS had started working, the saleman's technical take was that "it takes time to get going". More likely, there's a loose connector making intermittent connection. We'll see.
You press the start button without pressing the brake pedal. This switches on the ignition. You then click on OK multiple times to get through the "press break pedal when starting" messages to eventually arrive at the menu. Go down to Service and select the option to display the pressures. This is what I am normally rewarded with...
Yes, not only flat but a perfect vacuum! None of this cooling to Absolute Zero nonsense... Mark
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 ![]() ![]() |
At last, the dealers computer is saying my car is finally in build!! 11 days late but something is happening!!!! 2012 Evoque
