Home > Faults & Fixes > Possibile engine failure due to dpf
Fighter3d
Italy 2008 Range Rover Sport TDV6 HSE Bonatti Grey
Hi
I saw many 2.7 v6 tdi with engine failure, can be because the dpf filter ?
Post #454695 Thu Mar 05 2015 12:14am
Disco_Mikey
Most UK TDV6s don't have DPF filters
Post #454704 Thu Mar 05 2015 7:03am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
I don't think a DPF was even offered as an option for the 2.7 Tdv6. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #454722 Thu Mar 05 2015 10:09am
Disco_Mikey
I have seen 1, but I think it was an SA import...
Post #454726 Thu Mar 05 2015 10:36am
flydive
Do not know about the UK, but my 2006 TDV6 did have it. '08 RRS TDV8
Post #454732 Thu Mar 05 2015 11:04am
BKHK
So did my 2009 2.7 TDV6
Post #454736 Thu Mar 05 2015 12:10pm
Fighter3d
Anyway i saw on autoscout24 and so many rrs had the engine changed from 40000 to 200000 km
I supposed that the Lion v6 it Was a fragile engine. After lot of search i understood that is because of the dpf filter
When it comes full, the Diesel injected into it to clean the filter goes back in the motor and in the lubrication oil
This causes obvious problems of lubrication
Post #454797 Thu Mar 05 2015 11:04pm
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
Given the other issues with the TDV6 (oil filter, oil pump & bearing shells) I would be surprised if you could isolate DPF induced failures.
I'm not aware of any issues with the DPF but the non-DPF versions are still able to lunch themselves with failure modes shared with the DPF versions. Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #454799 Thu Mar 05 2015 11:16pm
Goreskin65
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Give terraclean a try, they clean out the dpf as good as new and a huge saving of many ££££s
Post #454993 Sat Mar 07 2015 2:59pm
