Home > General > RRS Window trims bubbling
ziglo
Hi all a couple of my window trims are bubbling on my Range Rover Sport, the dealer wants around £45 for one window trim which is overpriced really, doesn't anyone know of any aftermarket window trims ? I can see some chrome ones but just want the standard black ones or anything but chrome
Thanks in advance for your answers
Smile
Post #454783 Thu Mar 05 2015 9:15pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Some on ebay .......... Thumbs Up
Post #454794 Thu Mar 05 2015 10:50pm
zaphod
I've got the same problem on one of mine... do you know how to remove the trims?
I was thinking I could just remove it, give it a rub down with emery paper to remove the rust and re-spray with some satin black paint and it should be good as new.
Post #454862 Fri Mar 06 2015 11:22am
ziglo
No longer a member of ebay due to bad experience although may get a friend to order for me thanks for that
Also I don't think the metal strip that starts corroding causing the bubbling can be removed and sanded down its moulded into the trim itself, I think once they're gone its a new strip needed Sad
Post #454927 Fri Mar 06 2015 10:24pm
Bodsy
Site Sponsor
They're rubber coated, just prise up and off and replace. Shimples! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #454929 Fri Mar 06 2015 10:37pm
zaphod
Well that sucks... especially at £45 a door. The ones on eBay may not even be in much better condition given they're 2nd hand. Might just have to bite the bullet... Rolling Eyes
Post #454939 Sat Mar 07 2015 12:05am
simbad111
had the same problem, decided to buy chrome rubber covers from powerful uk, easy to fit look great too,
Post #454975 Sat Mar 07 2015 1:42pm
zaphod
Do they replace the existing ones or just go over the top of the old ones?
Post #454983 Sat Mar 07 2015 2:05pm
simbad111
they fit over the top, m3 tape very easy to fit and look good, if you pm email I will send you some pics fitted
Post #454995 Sat Mar 07 2015 3:10pm
Stuart
Mine are bubbled too, any chance of posting the pics up Simbad? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #455001 Sat Mar 07 2015 4:21pm
simbad111
with trims fitter over the rubber trim,
Post #455014 Sat Mar 07 2015 5:26pm
simbad111
look at my gallery photos should be there
Post #455015 Sat Mar 07 2015 5:28pm
zaphod
Thanks for posting those - they look really good... thought they might be a bit blingy being chrome but they actually look quite understated. Think they'll be going on my never ending shopping list! Laughing
Post #455022 Sat Mar 07 2015 6:48pm
ziglo
Those chrome trims look great on your car, but the existing bubbling trim wouldn't allow those chrome trims to sit flush wheb sticking on
Post #455029 Sat Mar 07 2015 7:30pm
zaphod
That's a good point - not only that but the old trims would just continue to rot away underneath leading to a worse problem in the future no doubt Sad
Post #455039 Sat Mar 07 2015 8:24pm
