Home > General > Annoying squeaky noise from the front, "HELP!!!
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Have this really annoying squeaky noise coming from the front of the car,
Can be heard at its worst at low speeds, on any sort of uneven road surface, turnings right or left.
Where do i start at locating this noise?
Post #454613 Wed Mar 04 2015 10:52am
D12TYJ
Anyone?
Post #454672 Wed Mar 04 2015 8:51pm
zaphod
Longshot but I had a squeaking noise from the front on mine... turned out to be the bottom door mouldings on the front doors. Some of the clips were broken and the mouldings were moving about when I was driving, although in my case it was only really apparent when I was going over 40...
Post #454733 Thu Mar 05 2015 11:16am
D12TYJ
I wish it was something as easy as that Rolling Eyes
It more of a mechanical sound, as if there's some sort of tension or something, initially I thought it could be the anti rol bar itself, but does the anti roll bar squeak when it's out or on its way out?
Seems to be getting worse everyday and can actually be heard from outside
Noise comes as soon as there's any movement of the car on any uneven surface.
Post #454758 Thu Mar 05 2015 5:58pm
zaphod
I'm no expert by any stretch but there's a lot of rubber bushes on various suspension components up front- if any of those have worn out I guess they could cause a squeak when they move about although I would have thought you'd get the odd clunk as well.
Hopefully one of the experts will spot your post soon and give you some proper help Smile
Post #454762 Thu Mar 05 2015 6:28pm
D12TYJ
Theres definetly a lot off clonks coming from the suspension everytime i go over humps Thumbs Up
Assume these are the lower ball joints and wishbone bushes, but this squeaky noise isn't definetly coming from the suspension, its an awful noise that i cant bear to hear anymore.
Post #454763 Thu Mar 05 2015 6:36pm
Marty151159
Hi
Had exactly the same problem with my 59 plate RRS which was more obvious the warmer the car became. Had independent garage extract front wishbone swinging arms and check bushes (which were ok) and completely re-lubricate only to have squeak return within an hour of leaving the garage. After much searching and re-searching both the garage and I came up with the front roll bar bushes were the culprit. Land Rover know about this common problem and have upgraded the replacement bushes with a polypropolene type instead and so far (a week later) no noise and car feels better and tighter in the steering.
Noise was really annoying and squeak got louder and louder
Post #469366 Mon Aug 03 2015 9:28pm
