![]() | Home > Technical > Oil leak from front of engine |
| nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274
Had similar recently and was told it was a crankshaft seal leak. £2,500 later repaired by local stealer. |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
By the looks of that pipe I would put a new one on, also check the top end of the pipe and make sure plastic chamber is seated fully home and the big circlip is located fully in.
| harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395
Seems like it could well be from front crankshaft oil seal. Have heard of quite a few of these leaks.Behind crankshaft pully. Have a look from top as well itisme |
| Tomrogers Member Since: 12 Jan 2015 Location: Mk Posts: 18 |
I'm assuming crankshaft seal is a huge job if he bill is £2500?
I had an oil leak,drips from front of plate under engine. Indie repair £318. They did a smoke test,and said the oil was coming from a badly seated Y section of manifold between V section of engine. £2 fr a new seal and £90 for cleaning all oil away. and top up oil and new filter.The rest was for smoke test and labour. I was just pleased not to have oil leaks all over the drive way itisme |
I'll have a proper look tonight from above once I take covers off fingers crossed it's a easy fix I can't be doing with a £1000 bill! |
Crankshaft oil seal is about 4 hours work, and a £4 seal
I was not very tight at all but I've tightened it and a drip still appears on the hose, what is this hose for? |
Intercooler/turbo hose |
In the same situation again I would not go to a dealer but a good Indie who I revkon could have halved the price. |
[quote="Disco_Mikey"]Crankshaft oil seal is about 4 hours work, and a £4 seal
And a decent Indy would be able to more than half that again |
| All times are GMT |
