Home > Faults & Fixes > press accelerator pedal, slight delay then car jolts away |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Hi ed
Sun Mar 01 2015 12:59pm |
ed68 Member Since: 15 Feb 2015 Location: Kent Posts: 14 |
Thanks Gogsy, it only happens less than 1 in 100 though so to select neutral every time I come to a stop is a lot of hassle for not much gain, I'd really just like to get the mechanical problem sorted. Also it doesn't feel like it's pulling off in 2nd gear at all, it pulls away with a lot of acceleration and drives normally, there is no lag or anything just a delay in the very initial pedal response
Sun Mar 01 2015 1:36pm |
CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 |
Have you checked that you don't have a sticky caliper.......had a similar issue on my D3 for 12 months, finally diagnosed when the caliper seized solid Over for a visit from disco3.co.uk |
Sun Mar 01 2015 3:13pm |
What you are experiencing might be the shift strategy built in to the software. JLR and or ZF decided it would be a good idea to build in several functions and one is called the stop go. If you are in stop go traffic where you are coming almost to a rest and then moving off again several times the software detects it and stays in 2nd gear without downshifting to 1st. If you stamp on the gas however it will (eventually) downshift and you get the 'scalded cat' takeoff.
Tue Mar 03 2015 3:23pm |
