![]() | Home > Technical > FBH getting on my nerves |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I think you are mistaken, the FBH doesnt operate at levels above 4 degrees, and certainly not anything around 10, the sound you hear is something totally different than the FBH running 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
If it bothers you, just unplug it. Although why you wouldn't want to use something that helps the engine warm up and be more efficient, I don't know....
andynpz Member Since: 20 Sep 2014 Location: Cotswolds Posts: 49 ![]() ![]() ![]() |
Thanks for the suggestion but I don't think I am. You quote 4C cut-off but in the 64 posts I refer to in my original post the cut-off temp. is listed at many different values up to at least 10C. Whatever, it is easy to check if the FBH is running if you open the bonnet and I am certain that it is. 2011 TDV6 HSE Stornoway grey, ivory trim Life's too short to drive an ugly car. |
I'm happy when it runs while the engine is also running - but I'm unhappy when it continues to run after the engine is switched off - burning fuel while going nowhere - that cannot be more efficient. Do you think unplugging would be better than removing the fuses? 2011 TDV6 HSE Stornoway grey, ivory trim Life's too short to drive an ugly car. |
It doesn't burn fuel at that point, it just cools it down by continuing to run the fan and the water pump for a short while.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9114 ![]() ![]() ![]() |
As Bodsy says, the noise you can hear is just the fan running to ensure it's cool before turning off completely. The fuel pump only runs with the engine running unless you have one of the many timer options fitted. 2012 SDV6 - it's missing a couple of cylinders
Thank you Bodsy and RRSTDV8, I am re-aassured to know that what i hear is just the shutdown sequence - certainly i have noticed the last 15 seconds or so are just the fan whirring as if purging the FBH.
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
Wish my would work its on and off like a light switch "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
