Home > General > Main Dealers, Don't you just love 'em?
Hi
Thought Heated Windscreen not working, never mind car still under Manufactures Warranty. Spoke to local main dealer, yes bring it in we will have a look at it while you wait.
Yes Sir have checked it out electrical circuit all ok, I'm afraid It need a new windscreen as the element has broken circuit, however we can't do it under Warranty as there is a stone chip in screen and this has caused the problem.
OK never mind I'll get it done under insurance as have windscreen cover. Sat at home thinking not convinced about this as there are Left and Right elements on separate circuits and the chip is on the l/h side of the screen. So out comes the trusty multi meter and did a continuity check on the fuses. Wow would you believe it both fuse blown, replaced fuses and lo and behold both side of the screen now working. If they can't diagnose blown fuses after the told me they had checked out the feed to the screen and that it was fine, what chance have you got if you have something more complicated, would have though first port of call would have been to check the fuses.
Post #453813 Wed Feb 25 2015 7:53pm
tanloverluke
hence the reason why I have never gone to a main dealer ! Luckily I have an indy near me who is brilliant! You've just proven a point also that many things can be solved at home, rather than a costly trip to this mob. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #453819 Wed Feb 25 2015 8:14pm
drdelrrs
I hope JLR take note - the lack of know-how (common sense for a mechanic) is unbelievable - Unless of course this was a straight-forward attempt at a rip-off!
Its quite depressing when there's seems to be very little enthusiasm in their dealerships for doing a good job.
There is no connection with the JLR's Marketing and PR hype about customer service and ensuring the job is done right - you'd have thought a first time fix was the cheapest solution for everyone!
JLR has adopted the arrogance from the success in emerging markets _ I recall Ford becoming arrogant in the 1970's and just prior to a period when they lost millions when they thought they knew better than their customers.
I guess we easily can work out who your 'local' dealer is.
Post #453820 Wed Feb 25 2015 8:14pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Hmmmm, think I'd be having a bit more than a quiet word with the service manager Rolling Eyes
Why not put the blown fuses back in, take it back and ask them to check it again. If they confirm the same diagnosis show the service manager what happens when you change the fuses & ask him if he fancies being a TV star on Rogue Traders Whistle
Post #453822 Wed Feb 25 2015 8:31pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Not a good story but some dealers are better than others ................
Post #453828 Wed Feb 25 2015 9:23pm
muddywheels
Milk Float Man
Can you tell me where to find one Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #453834 Wed Feb 25 2015 10:52pm
362bkr
I can tell you Muddy but then I'll have to kill you ! Rolling with laughter
Post #453841 Wed Feb 25 2015 11:15pm
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Brilliant idea and video on your phone and then post.
Post #453848 Wed Feb 25 2015 11:45pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
It's not just jlr dealers - but all shops - depends on the tech they actually have work on your car. Some are smart and very good- some rush and make mistakes and others are just plain dumb and forget to fill your trans fluid after draining, forget oil drain plug washer, don't torque to right specs and strip threads , etc. Etc.
Find a good indie that does the work himself - dealers often let "trainees" loose on your car and down shops hire minimum wage guys from the quickie lube ... Neither of which is good idea. I've seen it all on many different luxury car models ...
Post #453852 Thu Feb 26 2015 2:39am
Col, is this at Ridgeway Oxford? If so, I'm not surprised at all. They did something similar to me three years ago with my rear heated screen. Told me they had checked it thoroughly and it was the screen causing the issue. Glass not covered by warranty so you owe us an hour's money for diagnosis. I later discovered that the connector to the screen was corroded. Had never been opened since it was built, I'm sure, so how did they check it? I cleaned it up and it's still working three years later...
The service desk guys are pleasant people but the workshop is staffed by mostly inexperienced "technicians" as I understand it. The ones who've worked on mine the last couple of times it's been in for warranty work have been atrocious - usually leaving things unclipped, incorrectly located etc. 2012 SDV6 - it's missing a couple of cylinders
Post #453868 Thu Feb 26 2015 10:11am
muddywheels
Milk Float Man
Following years of problems with 9 LR dealers in my area I was going to try Oxford next time as I spend a lot of time there now Thud Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #453869 Thu Feb 26 2015 10:29am
SingeRRS
I cannot agree more with the comments on this thread - I have endured all these frustrations with multiple dealerships in my area. They seem content to take no care and the path of least effort and then charge exorbitant labour rates whilst warning about independants. It is frankly a disgrace for a premium marque to allow their dealerships to consistently behave in this manner - but as has been pointed out so long as they sell cars they don't care.
There are a large number of Discos, Sport and FF owners around us and many of my friends own one variant or another. They to a very large extent also share these views and I am seeing a big shift as existing LR owners move to other marques as a result of the painful dealership experiences - although they do forgive the endless faults more readily than I was prepared to. They are being replaced by a swathe of new first time LR customers who I presume will end up at the same conclusion in a few years unless things radically and quickly change. The number of new Sports on the school run disappearing into the garage within the first year of ownership is appalling.
This trend has also been evidenced by a local dealership running a "VIP event" offering "big discounts" for previous customers. The number of texts, emails and calls I have had asking if I would attend has been extraordinary. The event was the extended "by customer request". Right!
I only use independents for servicing - an excellent ex LR tech who left as the big companies took over the dealerships, paying huge sums for them and driving costs into the ground - with the results we now all see. I guess only sales performance over the coming years will tell if this strategy can work - but if it doesn't it will be too late for LR.
Post #453878 Thu Feb 26 2015 11:44am
You could try James French nearby. Well regarded locally. They've done one bit of work for me so far and I shall use them for my forthcoming service. Their hourly rate is significantly lower which is a nice bonus. 2012 SDV6 - it's missing a couple of cylinders
Post #453882 Thu Feb 26 2015 12:05pm
steve2026
2005 Range Rover Sport Supercharged Vesuvius Orange
I'm always reading on here about bad experiences at main dealers, ( really have to search for any positive comments ), personally I've been bitten once and am finding it hard to get back into ownership again, ( although I simply love the looks of the sport ).
Why is it that people keep going back to main dealers for any work or servicing required, after all, you don't have to, your warranty is still valid if you go to a specialist garage. 2005 Vesuvius 1st edition ( now sadly gone ).
Post #453883 Thu Feb 26 2015 12:13pm
SingeRRS
I agree and when I canvas people I usually get the same response - to protect my warranty. I know this is not required and when I point this out I get one of two replies:
1. I booked it in for a service and XYZ wasn't working and I wanted them to look at it under LR warranty. Indys can't? do warranty work.
2. Because I know if I send it to an Indy for the service and something goes wrong LR will blame the work or parts the Indy has done and refuse the warranty claim.
So I think the answer is convenience and fear.
I should point out I use an Indy and still have 9m of manfacturers warranty left.
Post #453884 Thu Feb 26 2015 12:21pm
