Home > Technical > Uneven suspension indicator - 4x4 info
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Hi all..
My O/S front suspension indicator (above the wheel) in the 4x4 info screen when in access mode _always_ flashes red / white. Doesn't matter where I'm parked, in which direction, it's _always_ the same wheel.. and will even stay flashing when moving slowly in access mode even though the camber of the road is changing for example.
Also, I decided to wash my RRS for the first time myself today as I had a bit of time and decided to raise it to off-road height so I could get under the arches easier with the jet wash.. but it took forever to raise the front - you could feel the rear was already at the desired height - and then I had a message appear on the screen on the dashboard saying 'suspension raising very slowly'.
Are these 2 issues likely to be linked? and if so, am I looking at the compressor or the likes?
The car's already been back to the dealer (non-LR) a few times to have various bits sorted and it's going back again on the 3rd March. Twice I've mentioned this indicator and twice I've been told "it's just telling you it's on an uneven surface".. but I'm not convinced, especially as mentioned, it's the same corner, no matter where I'm parked.
Unfortunately I don't have any access to diagnostics tools yet, so I can't plug it in and see if it's something listed within that, but if anyone has any ideas that I can then throw back at the dealer and finally get it sorted, then I'd be grateful.
Here's a photo:
Cheers..
Ian
Post #452821 Tue Feb 17 2015 5:58pm
Bodsy
Site Sponsor
Hi Ian, whereabouts are you?
It does sound like that front right sensor either needs calibrating or is faulty. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #452826 Tue Feb 17 2015 7:20pm
Ian.H
Hi Bodsy..
I'm in NW London.
It seems it's not just off-road height that's affected, any raising of the suspension results in the front taking forever with the message appearing on the dash (I normally leave it in access mode when parked, but alas, I won't be touching it until I get it sorted now as I don't want it stuck in access mode).
It's a real PITA. Luckily I've had everything sorted thus far under warranty, but it's just yet another thing to go wrong in the 3 months that I've had it.
Thanks for the thought about the sensor. I didn't think that it was just doing that on the same wheel for fun.
Cheers..
Ian
Post #452847 Tue Feb 17 2015 10:36pm
The slow raising could indicate a tired compressor or a valve block issue. The valve blocks aren't expensive - about £100 each - and relatively easy for a garage to fit. There are three of them, one for each axle and one for the reservoir tank that also directs air to each axle block.
The red line above the wheel indicates a possible height sensor issue - although it can also be caused by the valve block. A height calibration isn't a long/expensive operation so probably best to start there. 2012 SDV6 - it's missing a couple of cylinders
Post #452855 Tue Feb 17 2015 11:08pm
Ian.H
Thanks mate... it's back off to the (non-LR) dealership on the 3rd March.. so will tell them this time that I'm not excepting the "it's on an uneven surface" this time.. fix it.
Also now had a rear parking sensor go down the pan and randomly the head unit will state "low power mode" and won't turn up to loud volumes... not having a great deal of luck with this motor.. but alas, hopefully when everything is done, there won't be much left to need to work on (fingers crossed!) and thankfully all having been done via warranty thus far.
Cheers..
Ian
Post #453794 Wed Feb 25 2015 4:37pm
Bodsy
Site Sponsor
Let us know how you get on. If getting low power mode whilst engine is running, then dodgy battery or alternator (or both!) Bodsys Brake Bible
See it HERE
Post #453812 Wed Feb 25 2015 7:42pm
Ian.H
Well the dealership have had the car for the week.. can't seem to reproduce the low power mode for the stereo. They're going to carry out some more tests on Monday apparently but hopefully, it was just a minor thing that has corrected itself (maybe the battery had been drained quite a bit when they had it before and my mianly short journeys hadn't quite replenished it properly).
After telling them I'd spoken to someone at Land Rover about the "uneven surface" issue.. they've finally decided to replace the sensor Smile
I don't know what the cause of the suspension collapse issue at the front is as yet, but apparently everything else has been rectified (suspension raising slowly, rear parking sensor, slight pull to the left, were the mechanical issues IIRC).. so hopefully all will be good again on Monday / Tuesday when they deliver the car back to me.
Cheers..
Ian
Post #455089 Sun Mar 08 2015 10:37am
Fingers crossed! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #455102 Sun Mar 08 2015 12:01pm
Ian.H
Well, they replaced the height sensor related to the suspension problems, but the raising issue is still apparent (argh!!).
It seems to raise fine the first time, but if you do it a couple of time, the rear raises fine, but the front takes "forever" and the 'Suspension raising vehicle very slowly' (or words to that effect) message appears on the dash.
It has however, once or twice, produced this message and slow raising on the first attempt... so it's off yet again on Monday Censored Big Cry
Cheers..
Ian
Post #455364 Mon Mar 09 2015 11:09pm
Bodsy
Site Sponsor
New compressor I suspect. Live values would tell you the temperature it's running at. Thumbs Up Bodsys Brake Bible
See it HERE
Post #455375 Tue Mar 10 2015 12:01am
Yep, sounds like the compressor... 2012 SDV6 - it's missing a couple of cylinders
Post #455381 Tue Mar 10 2015 12:09am
Ian.H
Well it was due to be delivered back to me today. They've had it since last Monday(!). After trying to claim there was nothing wrong with it, and that I Must keep emptying the compressor tanks (I don't sit there playing with the heights! it goes into access mode when parked for easy of our young lads getting in and out and only goes into off-road height when I want to wash under the wheel arches).. they called me yesterday to arrange re-delivery and said that they had reconfigured the suspension.. I figured it was a possibility, due to the height sensor having been replaced on the front and that the rear raises without issue... alas, I got a call lunchtime today saying my car was "playing up again" and that they've now had to order another part that's due in tomorrow.. argh!
I've had this motor since October, and thus far, I've had nothing but problems with it. Luckily everything has been dealt with under the 6 month warranty I got with it, but out of the 5 months I've owned it, they've had it back for about 5-6 weeks Sad
I don't know what component they're replacing as yet, but will be asking when I get the call to say it's done again.
All in all, with the journeys back and forth, there's been about 1000 extra miles put on it (unfortunately, the place I got it from isn't local to me, but figured they could put it right, especially as there were other arguments I had with them about certain things). It's clocked ~70k now, so 1000 miles isn't something I'd sniff at if I'd put them on it, it's just principle in that I seem to get it back with either half a job done, or the fact it's just somewhat of a lemon. The only reason I've stuck with it, is that hopefully once everything's done, it'll be pretty robust with the fixes they've had to do.
Time to start studying up on the best warranty to get as the current one expires in April and the way things have been going so far, I certainly don't want to be without one!
I've wanted an RRS for years, but right now, wish I'd never swapped my Focus RS for it Big Cry
Cheers..
Ian
Post #457039 Tue Mar 24 2015 5:07pm
hse-lee
Ian H i feel your pain i too bought my car car late last year december and so far It has had
rear discs & pads changed as a dodgy caliper carrier warped the discs
arb bushes, lower wishbones, ball joints
4 x shock absorbers
new spare wheel winch
and awaiting to be fitted nearside front driveshaft
and yet still it is still doing more knocking underneath than some of the 'shops' down Soho
the new breaks are squealing so loud i want to sink in the seat out of embarrasement Embarassed
i too have just noted that my 4x4 screen is doing the same as yours and same wheel funny enough
I've always wanted a RRS and was so excited to get one but i too am now so regretting selling my bmw for this i plan to Bow down Bow down that eventually it will come good if not i may be back at the german dealerships sooner rather than later Big Cry
good luck with yours
Post #457050 Tue Mar 24 2015 7:15pm
riverblanche
Ian.H just think how good it will be when you have everything sorted Thumbs Up
if you get a warranty make sure if covers the turbo's Whistle
they are great when going well, had mine just over a year, only fault if the FBH not wanting to fire up Rolling Eyes but with some life support its getting there.
replaced front pads, serviced it and had a gearbox flush but they are standard maintenance.
although previous owner did. compressor. egrs. glowplugs. alternator. battery. front and rear arms. all discs. all belts Very Happy
don't become the "previous owner" Thumbs Up
Post #457067 Tue Mar 24 2015 9:24pm
Ian.H
Thanks lads Smile
Well, I got the car back on Friday. After speaking to service in the morning and them telling me it'll be coming back when the driver has returned.. I asked them to give me a call when they're leaving as I'm not currently at home... I got a call about an hour and half later... "the driver's outside your house and there's no answer"... no "£^% Sherlock! They parked the car on my driveway and posted the key through the letterbox as they couldn't wait 20 mins for me to get back, which was a bit of a PITA as I wanted to test things out before the driver went on his way again.
Anwyay... thankfully, the suspension issue appears to have been rectified. I'm not sure yet as to what was actually replaced, but I am planning on asking for a complete printout of the job sheets for my car so I know, and if I sell it in the future, I can hand over the information to the next owner what has actually been changed and when.
I think to date, I've had:
  • Switch in driver's seat replaced that caused multiple electrical failures, such as sunroof closure, memory seat positions, mirrors and steering column not adjustable, etc
  • Front wishbones
  • Front ARB bushes
  • Front ball joints
  • Front height sensor(s) to fix the flashing red indicator in the 4x4 info screen
  • Brake discs all round
  • Brake discs all round 1000 miles later due to warping, despite them telling me "you've driven this hard" (I haven't at all).. checking behind the front wheels, the calipers are brand new now! so I wonder what the problem was Laughing
  • Front calipers
  • Something related to suspension that caused the raising issue (unknown at this point)
I _think_ that covers it all!
Just got in contact with my current warranty company (The Auto Group) which I got 6 months worth of Ultimate cover with the car, and they've quoted me £796 for 12 months, which covers all engine, gearbox etc issues, including turbos.. so I think I'll be continuing the policy with them as thus far, there's been no problem with any of the work I've had done with them (the dealer has done all the work with them so to this point, I've not got involved at all except hand over the keys and receive them back again when the work's been completed).
They are lovely motors when working (albeit missing some of the basics IMO compared to other cars.. the biggest "annoyance" for me is lack of global closure / opening... my 04-plate E46 330 convertible could open and close the windows _and_ the roof from the key, yet an 80 grand motor new doesn't have said feature.. argh!).
Onwards and upwards! Very Happy
Cheers..
Ian
Post #457888 Wed Apr 01 2015 1:49pm
