![]() | Home > Detailing & Car Cleaning > settings for autobrite lance |
steve2026 Member Since: 30 Dec 2009 Location: Glos UK Posts: 122 ![]() ![]() |
Not sure about that particular lance, but the best way is to experiment, it depends on water hardness as well, the softer the water the better the foam.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
put an inch of magifoam in the bottom, top up with hot water to about 5 inches
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 ![]() ![]() ![]() |
thanks guys
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
I stay on a dry car. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
The general idea of foaming etc is to get as much dirt and grime off before you touch the bodywork with any mit or sponge, thus reducing the risk of damaging the finish of the paintwork.
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 ![]() ![]() ![]() |
Make sure EVERY TIME you use it, fill the bottle back up and flush the foam out of the lance. If you don't after a couple of months it will block up and it's a bit tricky to take apart, to clean it properly. Had mine a year now and still works like new and use it 3 times a week MY 13 3.0 SDV6 HSE Black Edition
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Jet washing also scratches the car by applying preasure on the dirty areas. Theres so many arguments for or against rinsing before foaming but altimately do what you think. Some people like the look of foam sticking on the car, personally I rinse lightly then foam and this is what I think works best. In my opinion. I'm not Fat. RRS TDV6 HST. |
Ill give both methods a try.
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
If you are going to jetwash first then make sure you have a nice wide spray pattern set and have it hitting the car at a 45 degree angle. This way the pressure is reduced (spread over a wider area) and also any grit that is dislodged should be deflected off the car rather than being pounded into the paintwork. |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
My usual order of things (for the body):
cheers zaphod, ill bare that in mind
Amen to that - cleaning the car at this time of year isn't that much fun if I'm totally honest |
Totally mate! My paintwork is in appalling condition right now as I've only had it 3 months and the weather's been pants.. can't wait for spring either to get out there with the polisher and sort it all out.
Bloody hell. Looks agresive stuff.i had never heard of onr until I googled it after reading your post. |
