Home > Faults & Fixes > Range rover sport went dead 07 Hse TDIV6
Page 2 of 3 <123>
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I've been to 2 independent garages for the alternator tested and both have readings of above 14 Thumbs Up
Post #453670 Tue Feb 24 2015 1:37pm
So where did your earlier 13.5V come from? Confused Glad to hear the alternator is sounding more likely to healthy. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #453709 Tue Feb 24 2015 7:42pm
samorano
hello good one you got there. so pls was the hazard lights still blinking when the ignition was switched ON immediately the new battery was fitted before clearing the fault codes?
Post #453718 Tue Feb 24 2015 8:18pm
monty19
Yes they did, I switched them off and made sure everything else was off before starting it
Post #453721 Tue Feb 24 2015 8:36pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Possibly got the lower reading from the sat nav screen. I'm not Fat. RRS TDV6 HST.
Post #453726 Tue Feb 24 2015 8:48pm
samorano
and hw did you switched them off? was it by clearing all the fault cods? and one more important question, after fitting in the new battery, did the engine management light came up or it was only after switching off the other lights before it finally came cuz i want to be sure if its the same situation i am facing
Post #453731 Tue Feb 24 2015 9:11pm
monty19
This was off the self test menu on the nav screen Thumbs Up
Post #453744 Wed Feb 25 2015 8:04am
monty19
When I fitted the new battery the indicators started to flash, I turned them off on the dash before putting the key in the ignition, not sure if its relevant but after turning the key I made sure everything was turned off, heater seats etc, all the faults were still there when I started it including the check engine light.
All the faults cleared quite quickly except the eml, this cleared after I stopped it and restarted it, hope this helps
Tony
Post #453745 Wed Feb 25 2015 8:11am
monty19
This might help Thumbs Up
Post #453746 Wed Feb 25 2015 8:14am
samorano
Tony
with mine, the eml donot even show up on the instrument cluster here is a video to mine
i hv also tried the self diagnostic but nothing like a fault shows up so there is no way for me to clear out the faults
Post #453773 Wed Feb 25 2015 12:07pm
monty19
Not sure if this will make a difference, I had no battery on the car for 2 days, you could try this and see if it works or search for the hard reset procedure
Post #453777 Wed Feb 25 2015 12:43pm
Lost for Words
I highly suspect you have a problem on the CANBUS somewhere. The only way you can deal with it is to start running over the wiring - a diagnostic tool can't help.
The wheel arches (front left in particular, I believe) are common places for wiring problems so I would start there. Thumbs Up
Worth a read: http://www.disco3.co.uk/forum/topic110716.html Wink Visiting from DISCO3.CO.UK
Post #453778 Wed Feb 25 2015 12:43pm
samorano
hey the technician found out that the main socket carrying the CAN signals on the Electronic parking brake control unit was totally out and when it was connected, everything came back to normal except the EML which did not still show up but they could communicate with all the control units as the engine could crank but do not start . i now feel relieved . i am going to stay with them throughout the workout today to keep you guys inform thanks alot
Post #453872 Thu Feb 26 2015 10:59am
Lost for Words
The EPB module and wiring is a common place for CANBUS problems. Thumbs Up Visiting from DISCO3.CO.UK
Post #453874 Thu Feb 26 2015 11:07am
monty19
Happy days Thumbs Up
Post #453895 Thu Feb 26 2015 1:46pm
Page 2 of 3 <123>
