![]() | Home > Faults & Fixes > Range rover sport went dead 07 Hse TDIV6 |
| Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91
Good luck with that. I have know idear what's up with your car. Maybe something needs resetting!
| samorano Member Since: 23 Feb 2015 Location: Manchester Posts: 11
yeah i hv thought of that but the local LR technician says the he cannot get access to the Transmission control and the engine control units which are all on the same CAN line he always ends with communication error |
| monty19 Member Since: 12 Mar 2014 Location: boro Posts: 326
Mines done exactly the same on Saturday with the same faults showing as yours, mines going into falcon performance on Wednesday for new alternator and battery, I think you need to get all the codes cleared aswell, mines getting collected by recovery truck.
But has urs been diagnosed already? or they just one to swap them first for test? they said they got the fault codes cleared but to no avail so |
Rac checked alternator, only giving 12.5 volts, the battery was goosed and smell of eggs in the car indicated the alternator was cooking the battery and it had a small leak of acid, fingers crossed this will sort it.
ok i will be waiting for my report from the technician but does your engine management light shows on the dash when you switch On the ignition? |
I've removed the battery shortly after getting home so I don't know, it was on for the 30 mile drive home, I'll fit the new one tomorrow and report back with any faults etc |
ok thnk you i will be waiting |
New battery fitted and all faults have cleared, I've done a HLDF test and I'm getting 13.5 volts when the engine is running and 12.5 when its off, I'll need to get a alternator check done now as I'm thinking it was only the battery that was at fault. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
13.5V is a bit low really. You should see over 14V. Mine runs at 14.5V when idling with the engine warm and that's with a known good, well charged, battery and an alternator that's 3 years old.
wow that's great pls what capacity of battery did you fitted on the vehicle? |
as i said my alternator and Engine control unit replaced but to no luck of which i started with a new battery |
Just had the alternator tested at the local garage and they have said its charging ok,
13.5V suggests otherwise... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| All times are GMT |
