Home > Technical > Locking car
craig51
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Fuji White
Locking car
Hi all, second post here.
Somewhere I read about the best sequence to leave the car.
I am pretty sure it was advised that when I come to a final stop, put car into access mode, then park and then hand brake.
Is that correct? Or just come to a stop and in park and then handbrake!
Thanks all.
Post #453192 Fri Feb 20 2015 9:45pm
fkarim
I follow this sequence after seeing advice on here:
1. Put in access mode shortly before stopping so it completes the lowering operation in time and doesn't do it with gearbox in Park or with brakes on.
2. Select Neutral, apply parking brake and lift foot off brake. The car might move a bit but any strain will now be on the brake shoes/discs rather than the gearbox.
3. Select Park and switch engine off.
4. Lock using the button on the door handle rather than the button on the remote. This means no one can catch or jam the signal which can be the first step towards stealing the car. Same thing with unlocking, just approach the handle with key on you and it will unlock. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #453197 Fri Feb 20 2015 10:13pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Holy Censored theres an actual procedure for stoping and locking your car?
I just pull up, drop to park, handbrake and off I go! I'm not Fat. RRS TDV6 HST.
Post #453200 Fri Feb 20 2015 10:27pm
fkarim
Not officially I guess. Just a few things people have thought about and considered good practice out of sympathy for the car. There is nothing to it once you get into the habit btw. Most people do most of these things anyway, just that the "right" sequence could have long term benefits (probably very long term). Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #453205 Fri Feb 20 2015 10:40pm
ilard
I vaguely remember seeing on TV when I was a lad that - once at a complete standstill - it's common practice to exit the vehicle via the front window, presumably to save wear on door mechanisms. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #453248 Sat Feb 21 2015 9:51am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I just stop, put it in park press stop and jump out. Rolling Eyes
Post #453250 Sat Feb 21 2015 9:57am
fkarim
Everyone has their priorities. I like to keep my car clean but don't get why some people are so anal about the "perfect shine" and get so excited when their paintwork "reflects like a mirror" etc. Mechanical sympathy is more important to me. Each to their own I guess Thumbs Up Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #453262 Sat Feb 21 2015 12:01pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Can I ask, as I'm sure a few are wondering, what difference does this make in the long term to the car?
Post #453272 Sat Feb 21 2015 1:07pm
fkarim
I think I already tried to explain my point of view but here it is again. I am no expert but this is what I have noticed and also read on the forum:
1. Lowering the suspension when in park or with brakes pressed makes a creaking noise. Obviously something isn't happy. Hence lowering while still moving or in neutral without brakes should avoid that.
2. Applying the parking brake when gearbox in neutral as opposed to park means when you lift your foot of the brake and the car moves a bit before coming to rest again (especially if you park on a slope like I do), the brake shoes and discs take the strain (which is what they are for) rather the the gearbox. This could increase gear wear. Obviously if the systems are intelligent and the car automatically does the right thing then this isn't a problem but I don't know so just try to be safe.
3. Locking the car using the door handle buttons rather than the remote could potentially prevent thieves catching the signal. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #453287 Sat Feb 21 2015 4:08pm
myfirstrrs
I'm with fkarim on this. Some of these things might not be 100% necessary but should all help to keep pressure off the gearbox and drivetrain. They're also easy.
Post #453288 Sat Feb 21 2015 4:27pm
