Home > Technical > Torque Convertor noise ??
rooby_roo
Hi all, i have just purchased from auction a 56 plate 2.7 hse sport , it has 183k on the clock with full history and 2 owners, as i was driving home i noticed a noise when i took my foot off the gas, almost like it was releasing air under the car, when i put my foot down again the noise went, also whilst at a standstill there is a whiring noise if i put it in d or r, but if i put it in n the give it a rev the noise goes when i put it in d again, the gearbox performs well, no juddering or slipping, plenty of power etc, is this the convertor on its way, or could the fluid be low etc, im fearing the worst. any info would be great thanks,
Post #452830 Tue Feb 17 2015 8:30pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Noise when releasing gas pedal. Could this not just be something like boost preasure being released from the turbo? Like pressure coming out of a waste gate or something? Not sure if they have them but perhaps try it in neutral see if you get the same noise.
As for whirring noise possibly torque convertor if its only in drive and reverse. Theres someway of doing a stall test to check if the torque convertors nakered. I think you apply the break hard and steadily apply accelerator preasure up to 2,000 revs. Search the forum for this.
Does the whining noise happen when driving or just while stationary? I'm not Fat. RRS TDV6 HST.
Post #452853 Tue Feb 17 2015 11:06pm
drdelrrs
You could try a 'stall' test. Check tranny fluid level first.
Put your left foot hard on the brakes and with the car in drive increase the engine revs - the torque convertor and gearbox should stall the engine. Do not hold the revs for more than about 10-15 seconds.
If you press the accelerator, and you get weird noises (its gearbox brake bands) or the engine revs continue to rise ( its torque convertor shot)
Post #452857 Tue Feb 17 2015 11:09pm
rooby_roo
Thanks ill try the test in the morning
Post #452960 Wed Feb 18 2015 11:25pm
rooby_roo
i couldnt find anyone to check the oil level for me so i did the test anyway, it will rev up to 2000 rpm but no more, i revved it for about 3 or 4 seconds, or if the oil is low would this test prove inconclusive ??
Post #453151 Fri Feb 20 2015 4:58pm
drdelrrs
If it stalled and there were no noises I'd reckon the torque convertors fine.
Post #453186 Fri Feb 20 2015 8:03pm
rooby_roo
No it didnt stall m8, i only revved it for a couple of seconds on 2000 rpm, would it have stalled by then ?
Post #453222 Fri Feb 20 2015 11:23pm
drdelrrs
"Stall" doesn't mean it killed the engine merely that the revs were held at a constant speed by the torque convertor at the engine's revs for producing max torque and thus max load on the drive-line while the throttle is wide open.
When a torque convertor is shot, or the transmission's brake bands are worn or the oil is loosing viscosity the transmission is incapable of holding the engine's output.
Its similar test (but obviously a slightly different procedure) on a car with a manual gearbox to see if the clutch is shot.
Post #453289 Sat Feb 21 2015 4:35pm
rooby_roo
ok ill give it another go, does it have to be up to temp ? or can i jump in it now and give it a go ? ill hold it on the revs for 5 secs
Post #453395 Sun Feb 22 2015 3:35pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi there, I have the same symptoms but at 2000 to 3000 revs. I’ve just tested mine & it stalled & got no noises etc, any ideas please Thumbs Up
Post #577183 Sat Mar 16 2019 7:16pm
