![]() | Home > Technical > Steering |
Tyre pressure, lower steering column is common. Bodsys Brake Bible
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4509 ![]() ![]() ![]() |
Broken wire to the servotronic valve on the rack. Very common issue |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Thank you. Will get it checked over this week. |
Brooksey90 Member Since: 31 Oct 2015 Location: North yorkshire Posts: 4 ![]() ![]() |
Hi
Check the RLM for fault codes first.
Thanks for the reply I will try get someone to plug into it and see what faults it's got is it work changing the fluid as it does look a little dark |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
I bought my RRS a few weeks ago and the guy said the steering was a bit heavy, when I went to see it but it was booked in for the bottom UJ. When I picked it up the steering wasn’t heavy but heavier than I expected especially after driving my FFRR with 20’s on.
