![]() | Home > Technical > The old suspension chestnut - help! |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
First things to consider:
| scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 |
lose height sensor ? |
| D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183
I would go with lost for words, as hes mentioned exactly what am about to write,
With the RRS and D3/4s having complex electronic systems, low or high voltage can cause havoc and it always the first thing to check. Particularly at this time of year too as batteries start to struggle in cold weather. I would suggest that a multimeter is an essential piece of equipment for any RRS owner. |
| fascinuk Member Since: 18 Apr 2013 Location: Cornwall Posts: 15
Thanks for these hints guys, what should the alternator and battery voltages run at?
A good, fully charged battery standing charge should be 12.7/12.8 volts.
Thanks Lost For Words, will get these checked out on Monday, really appreciate your help mate Roger |
No problem; I like to help when I can. |
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948
Im more interested in the full tasnk of fuel ha ha, I bet this is because of the drop in prices, is every body driving round on a full tank? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
| JCHarris Member Since: 01 Jan 2015 Location: Solihull Posts: 18
Can't be posting pictures publicly looking like a cheapskate!! |
Hi, quick update, had battery and alternator checked and its reading 14.4 volts, so assume that there's no probs there!
| Rob_h Member Since: 11 Feb 2015 Location: North Posts: 16
If it's like a d3 I had a problem with the connector within the front passenger wheel arch which is a known problem on the d3 ? Not sure if it's the same on the rrs though but might be worth a check ? |
The wheel arch wiring and connectors can cause issues but there aren't the signs of a full CANBUS hissy fit and the simple things need to be ruled out first.
Update : New brake switch fitted and had the 'suspension fault vehicle lean when cornering' warning come up.....so it's not the brake switch, battery or alternator .......next??!!! Roger |
