![]() | Home > In Car Electronics > Sat nav wont let me access postcode |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
Check if you can enter numbers for postcode and just not alphabets. If so, most likely the country has reset to Belgium where postcodes are numeric only. Expected to happen after a battery disconnection/reconnection or replacing the map DVD. Change it back to GB, should be good then. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
| D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183
Will try this on my lunch break, hopefully its something just as easy as that.
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948
it will be that |
Thanks guys, worked a treat.
I believe the sat nav company LR use is Belgium based, so after power loss it always defaults to there |
| Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46
Suits me just fine |
| All times are GMT |
