Home > Maintenance & Modifications > D3 ARB bush replacement same on RRS?
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Has anyone on here done a write up on doing a bush replacement on a 2.7 RRS?
Post #452133 Tue Feb 10 2015 8:45pm
flack
Gaz send me your vin number and I can check it for you..
Flack Thumbs Up
Post #452134 Tue Feb 10 2015 8:54pm
Gaz
Legend!.....thanks Flack!
Will PM you! Thumbs Up
Gaz.
Post #452137 Tue Feb 10 2015 9:00pm
flack
Gaz its Active on your sport
Flack Thumbs Up
Post #452140 Tue Feb 10 2015 9:20pm
Gaz
Thumbs Up ......okay....so,
Straight forward to do the rear ones?
Front ones.....not so simple?
Post #452143 Tue Feb 10 2015 9:40pm
flack
No both back and front are not as easy if you just had the dumb anti roll bar..
Flack Thumbs Up
Post #452144 Tue Feb 10 2015 9:43pm
Gaz
I've searched and searched but I just cannot find a how to guide on this particular type of bush change.
Post #452148 Tue Feb 10 2015 10:01pm
flack
Thats because you really need a ramp to change this type of bush and its not an easy DIY job..
Flack Thumbs Up
Post #452150 Tue Feb 10 2015 10:12pm
Gaz
Called my garage today.
They will fit both front and back for £110 using the bushes I've purchased.
Pointless struggling for that money!
Thanks Flack Thumbs Up
Gaz.
Post #452184 Wed Feb 11 2015 10:28am
RRSporter
I have to agree with Flack. Did my front active RRS bushes today - 6 Hours. Left side needs propshaft undoing and tying out of way which gives you about 2 inches to play with. Right side has active bar hydraulic lines right in way as well. You can't get a socket on ANY of the 6 bolts!! Even with bolts out getting the drivers side bush in is next to impossible! If you were brave would have been made easier by disconnecting hydraulics to bar to remove these pipes but there's obviously risk of ingress of dirt etc so I left those well alone.
Tbh £110 to fit is a steal for an active bar. It's an awkward messy finger nipping job.
What I would say it that there were no obvious wear signs prior to dismantling, using a pry bar etc. I almost didn't bother after looking. However my car had only just started to knock when steering left right etc at 30 mph which seemed to be a good test. As the drop links had no wear it had to be the bushes really. I'm very happy to report it was them!
So in summary everybody don't be fooled by the how to guide for the D3 which appear straightforward. I'm a mere diy'er not pro like Flack. These were not straightforward. And mine weren't seized or rounded off etc etc... 3.0 SDV6 HSE L494
Post #462283 Mon May 18 2015 10:54pm
DerrekL
Hi when you say...
is there any particular way I have to check /mark the way the prop comes out or is it a case of removing the bolts of the prop and easing it out the way?
I have so far done the drivers side and went to do the passengers side the same day and could not get a spanner/socket anywhere near the three bolts.
cheers RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #472155 Sun Sep 06 2015 1:19am
RRSporter
Remove bolts in propshaft flange and yes mark where it originally went to be sure it goes back in the same place. Bit of a faff as I recall having to turn the shaft to get to all the bolts. Eg lots of gearbox changing from P to N etc but otherwise it's straightforward. It will probably be stuck with all bolts out so a small blow should do the trick. I would recommend new bolts on reassembly however. Good luck! 3.0 SDV6 HSE L494
Post #472175 Sun Sep 06 2015 10:31am
cookie7280
2007 Range Rover Sport TDV8 HST Orkney Grey
hi I aim attempting this on my vehicle I have removed the 6 bolts but cannot get the prop to realease. does it just need tapping back? it is almost like there is weight on the drive still?
Post #477132 Tue Oct 20 2015 10:47am
