| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > car shakes at 70mph- help |
| Goreskin65 Member Since: 07 Jan 2015 Location: Portsmouth Posts: 32      | Parking brake shoes worn, it's what I had the vibration came on at 70 so I reduced to 50 then it disappeared and was told on here it's the EPB | ||
|  Sun Feb 08 2015 10:46pm |
| king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7      | Thanks. Will the parking brake do this? Other times I drive at 75 /80 mph, no issue. Its only a few times at 70 mph it has ocurred. Parking brake operates fine with no issues though? | ||
|  Sun Feb 08 2015 10:51pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | parkig brake or any of the calipers sticking.   | ||
|  Sun Feb 08 2015 11:05pm |
| Goreskin65 Member Since: 07 Jan 2015 Location: Portsmouth Posts: 32      | Honestly chap it was bodsy who told me about the fault  | ||
|  Mon Feb 09 2015 8:50am |
| king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7      | I believe you.lol. But the independent i'm using aint having it. I'm taking it round there next monday. | ||
|  Mon Feb 09 2015 11:29am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | it goes after you drop the rev's....? probably not the brakes then, could be EGR valve fluttering, or possibly cross over pipe leaking causing some spurious issue? Bodsys Brake Bible
|  Mon Feb 09 2015 12:38pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Check the center prop mount, it might have perished, or the bearing gone...
|  Mon Feb 09 2015 1:03pm |
| kevtydd Member Since: 28 Jan 2015 Location: llanrwst Posts: 5      | I had something similar lately on my 58 rrs tdv8 hst .About 10 miles after leaving a hand car wash place the whole vehicle was vibrating at about 60 ! Pulled over and had a quick look incase of loose wheels , but nothing, so carried on home and nothing since ! Don't know whether water from jetwash they used got into something under arches ? oOk now , fingers crossed ! | ||
|  Thu Feb 12 2015 7:20pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | You might want to check the harmonic dampers (two weights, either side behind the rear wheels) swing freely and aren't contacting the bodywork. | ||
|  Fri Feb 13 2015 4:22pm |
| king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7      | Well took it to the garage, found an EGR fault which he is blanking out. He states its a gearbox issue and possible need a gearbox change. Don't know if I believe him as it drives perfect round town and on country roads at 50 / 60 mph but will try a gearbox flush and see what happens. Hopefully the EGR blanking may help also. It's a waiting game. | ||
|  Mon Feb 16 2015 8:39pm |
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157      | Hope you got it fixed. I had exactly the same issue, and mine was water in the tyres. | ||
|  Mon Jun 29 2015 6:31am |
| king9750 Member Since: 31 Jan 2015 Location: Maidstone Posts: 7      | Well,
|  Mon Jun 29 2015 7:36am |
| Posting Rules
