| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Suicide hesitation |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | .....would I also be correct that if my 2.7 TDV6 is on an 07 plate, that fitting the blanking plates wouldn't throw up an ECU error???
|  Sat Jan 31 2015 9:08am |
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186      | Gaz I'm not sure 2007 onwards RRS can be blanked yet, as fitting the blanking plates will trigger the EML light. 2014 L405 SDV8 RR Autobiography  | ||
|  Sat Jan 31 2015 9:09am |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Hmmmm.....Thanks Joe.
|  Sat Jan 31 2015 9:10am |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | ....ahh right.
|  Sat Jan 31 2015 9:13am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | You need a good remap, changes the car completely.
|  Sat Jan 31 2015 9:57am |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | There's a fairly sizeable old thread on this which I'm going through on here now....
|  Sat Jan 31 2015 10:09am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | As I understand it some 07/08 MY cars may be running old historic engine software, hence they can get away with just blanking the EGR valves, however if your car is serviced properly then the dealer should have updated/flashed the ECU's to the latest level. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Sat Jan 31 2015 1:14pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | I've only gone and found a specialist that offers a service of installing the blanking plates and carrying out a re-map to improve efficiency, power and tells the ECU to ignore the EGR data!!
|  Sat Jan 31 2015 4:28pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Just be aware that EGR operation "may" become part of the MOT, hence why fitting emulators may be the preferred option.   | ||
|  Sat Jan 31 2015 4:55pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Hi SRE!
|  Sat Jan 31 2015 5:13pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Gaz
|  Sat Jan 31 2015 5:54pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Do a search on the Disco 3 Forum, there is bound to be some info about this on there.  | ||
|  Sat Jan 31 2015 5:56pm |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | .....wow.....that does throw a spanner in the works doesn't it.
|  Sat Jan 31 2015 7:51pm |
| FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259      | Can't see MOT stations checking for EGR vavles. I'm not Fat. RRS TDV6 HST. | ||
|  Sat Jan 31 2015 9:23pm |
| Posting Rules
