Home > Technical > Raspy noise when lifting foot of Accelerator
Page 2 of 4 <1234>
Disco_Mikey
ACE 219 wrote:
It's not the gearbox
I've replaced my gearbox & still have this noise.
Read my post about it. You'll see that it's the torque converter moving towards the gearbox.
I'm not sure how or why the torque converter can move towards the gearbox because its bolted to the drive plate which is bolted to the crank.
I measured the end float on the crank which is well within the tolerances.
Someone hopefully knows how & why this happens & now to fix it.
Any advice would be greatly appreciated.
You replaced it with a 2nd hand box IIRC. May be a worn pump inside the box, or something inside the box allowing the TC to move in and out
Post #450412 Fri Jan 30 2015 6:28pm
ACE 219
http://www.rrsport.co.uk/forum/topic2725-90.html
If you read this you'll see that Land Rover have admitted there is a design fault with the TDV6 engine & they say its characteristic to the RRS & Disco3
Post #450413 Fri Jan 30 2015 6:34pm
ACE 219
I replaced the transmission with a tested used transmission.
You can but a brand new transmission & fit that but it won't fix it.
I also fitted a brand new pump to my transmission but that didn't fix it.
The torque converter isn't fixed to the transmission so it's impossible that the transmission can move the torque converter.
The torque converter moves due to centrifugal force.
Check YouTube on how a torque converter works. It's easier than me trying to explane this.
If you go back to Land Rover get them to put your car on a 2 poster ramp & you'll see for yourself the torque converter flexing to flex plate which makes the noise.
Let me know how you get on.
Post #450417 Fri Jan 30 2015 6:42pm
Hamner
Wales
hi ace wow youve done some work on this problem Bow down your alot more advanced than me keep in touch if you work it out thanks for your help anyway Hamner
Post #450433 Fri Jan 30 2015 7:12pm
Disco_Mikey
M gearbox will be replaced very shortly (for other issues) with a brand new unit, so we shall see what happens Thumbs Up
Post #450440 Fri Jan 30 2015 8:18pm
Hamner
Wales
nice one Mikey i will be very interested to see what happens with that thanks for the up date Thumbs Up cheers Hamner
Post #450443 Fri Jan 30 2015 8:48pm
ACE 219
I agree please keep us posted as the more info we can get the better chance of finding a fix.
Make sure you check the drive plate for cracks when you've removed the gearbox. I fitted a new drive plate although there was nothing visually wrong with mine.
If you get the chance measure the end float on the crank too.
Post #450497 Sat Jan 31 2015 8:38am
Hamner
Wales
hi ace any news on the rasping noise we were talking about a few weeks back cheers hamner
Post #452382 Thu Feb 12 2015 8:09pm
Hamner
Wales
Post #452384 Thu Feb 12 2015 8:12pm
drdelrrs
Two-penneth !
An alternator can make this sort of noise under over-run conditions.
Do you get it when backing off at cruise speed in top gear when the tranny has achieved 'lock-up'.
Can you vary the tone by backing off quickly or backing off slowly?
I'm sure all you guys have checked but are you 100% sure the auto-transmission fluid is to the correct level ?
Post #452437 Fri Feb 13 2015 4:15pm
Hamner
Wales
hi mate thanks for your input one of the guys here has changed the the gearbox trying to sort this noise out and then moved onto the torque converter which he found to be moving or rather what it is bolted to was flexing then one of the guys though it was from the gearbox and was going to replace it with a new unit and thts as far as weve got upto date cheers Hamner
Post #452450 Fri Feb 13 2015 5:44pm
Disco_Mikey
The supply of new gearboxes has dried up, so will have to be a re-con unit from Land Rover. Need to see what my VAT return is going to cost me, before I splash out Big Cry
Post #452461 Fri Feb 13 2015 7:21pm
Hamner
Wales
hi mikey thanks for the up date i know what you mean im in trouble with the Ni man myself
Post #452462 Fri Feb 13 2015 8:05pm
ACE 219
Did anyone find a fix for this yet? RRS TDV6 Overfinch
Post #461600 Sat May 09 2015 9:22am
Hamner
Wales
rasping noise
hi ace , i was thinking of this just the other day , ive not found afix yet my rasp is still there no better or no worst i was thinking of having the tc refurbished but at 800 pounds i cant do it at the moment ,but thats as far as ive got regards hamner
Post #461612 Sat May 09 2015 11:44am
Page 2 of 4 <1234>
