Home > Maintenance & Modifications > EGR blanking
Page 2 of 4 <1234>
Disco_Mikey
I nearly fainted at the price of the Allisport intercooler Laughing
RS500 cooler was £120 from eBay, and another £30 on pipes ans hose clips, and job done Thumbs Up
Post #449714 Sun Jan 25 2015 12:58pm
Lost for Words
At least I got it at trade price from Brookwells. Shame I missed the pricing error though. Big Cry
If I were to do it again I would go for the RS500 without a doubt though. Whistle Visiting from DISCO3.CO.UK
Post #449719 Sun Jan 25 2015 1:26pm
Fritz
Germany 2006 Range Rover Sport TDV6 SE Java Black
I managed to get a trade price from Alisport so it was not to painfull. Having looked at the RS500 it does not look very tailor made as the Alisport.
Post #449751 Sun Jan 25 2015 7:48pm
Disco_Mikey
The RS500 is not a direct fit, and does require a little modification to fit, but it's a £350 saving, and is actually a bigger cooler Whistle
Post #449768 Sun Jan 25 2015 8:37pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I'm going to do the EGR blanking and seen a few kits on eBay but they range from £17 to £100 but look the same.
Is there any difference. The guy selling the kit for £100 has the same bits in as the £17 kit and he's sold 36 of them?!
Why would people pay £100 for this when they can get it cheaper? Is it better?
Would I be ok with the £17 kit?
Post #449978 Tue Jan 27 2015 7:45pm
Fritz
EGR Blanking kit
For my money the DA1112 from Britpart is the most comprehensive, don't forget to remove the butter fly valve from the air inlet.
From memory the kit comes with a comprensive fitting instruction.
Can also recomend a Hiclonehttp://www.rimmerbros.co.uk/ItemList--Hiclone--m-12572 in the air inlet after the air filter, not so much for fuel saving but performance.
Post #450024 Wed Jan 28 2015 7:46am
Disco_Mikey
Nothing wrong with a pair of £5 blanking plates. Does exactly the same job Thumbs Up
Post #450027 Wed Jan 28 2015 8:28am
Nsp1
Cheers Disco mikey.
Just couldn't understand why people are buying them at over £100 when others were £17.
I'll get the cheaper ones.
Post #450028 Wed Jan 28 2015 8:30am
Disco_Mikey
Mine were even cheaper. Made out of a scrap piece of angle iron that was lying around Laughing
Post #450033 Wed Jan 28 2015 9:26am
Nsp1
I've heard of people cutting a coke can up and into the shape of the blanking bit but I'll stick to eBay.
Post #450082 Wed Jan 28 2015 4:58pm
Nsp1
In my instructions it mentioned nothing about butterfly valve.
Plus I'm having trouble removing the torx screw on the left pipe. I just can't get to it. I can't think of any tool that will fit.
It's the lower screw at the top of the pipe. Can anyone help please as I need the car tomorrow afternoon and it's just a nightmare.
Post #450810 Sun Feb 01 2015 9:20pm
Lost for Words
Have you seen this?: http://www.disco3.co.uk/gallery/albums/use...0SMALL.pdf
Have you unclipped the pipes and twisted the butterfly housing up (don't go too far)?
You need to remove the butterfly valve or it will block off the air flow when it shuts. Thumbs Up Visiting from DISCO3.CO.UK
Post #450869 Mon Feb 02 2015 11:19am
Nsp1
Thanks for the instructions.
What a pig of a job!!!
Especially that bottom screw going into the air box.
Took me ages to get that out. If it wasn't for that plastic fan cover then it'd be a lot easier.
Felt like cutting through it but I stuck at it and got there eventually after dropping the spanner & socket into the engine.
Glad I had one of those extending magnetic things so I could retrieve them.
I've not driven the car yet but I'm off to work later so I'll let you know if I find any difference.
Post #450887 Mon Feb 02 2015 2:12pm
Nsp1
Not much difference really.
Unless there's something going on that I'm not seeing.
Oh well.
Post #451722 Sat Feb 07 2015 7:37pm
Disco_Mikey
If you didn't notice a difference, your valves were probably working OK Thumbs Up
But they will fail at some point, so at least now you won't be stranded
It may be worth checking your turbo hoses, as I have seen a few split shortly after blanking off the EGRs Thumbs Up
Post #451734 Sat Feb 07 2015 8:30pm
Page 2 of 4 <1234>
