Home > Technical > Car won't stay down.
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all,
Went to the car wash today and tried to lower the car so the guys could reach to clean the roof.
Pressed the button and it went down but straight away came back up. Then went higher.
The light on the button was flashing and on the dash it showed extended height (or whatever you call it).
Can anyone help please as I looked a right idiot.
Thanks
Post #449142 Tue Jan 20 2015 8:09pm
Paddi
Sounds as if your RRS is trying to tell you something; " no no ..... Please don't let those Censored s near me (sob). Can't you just get some nice snowfoam and a quality shampoo and clean me lovingly yourself Big Cry I'm sick of all these swirl marks and scratches. How about a nice bit of clay bar prep and a nice wax?" 2008 MY Java Black TDV8 HSE
Post #449147 Tue Jan 20 2015 8:25pm
Disco_Mikey
Blocked compressor drier, faulty height sensor, or poor calibration will all cause your issues Thumbs Up
Post #449148 Tue Jan 20 2015 8:28pm
PEACHY
Bow down Bow down Bow down so true Thumbs Up 16MY Estoril Blue SVR.............
Post #449149 Tue Jan 20 2015 8:29pm
Nsp1
I know, I know, but it's cold out there and nice n warm in the cabin with the heated seats.
Post #449158 Tue Jan 20 2015 9:01pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
This is really weird. I had to take mine to the scratchers the other day too, I was desperate and it was too cold and guess what, this happened to me however it works absolutely fine every other time so I think its just really trying to tell us something Smile
When my mobile valeters snow foaming it the suspension works fine Smile I'm not Fat. RRS TDV6 HST.
Post #449166 Tue Jan 20 2015 9:25pm
Nsp1
It's still doing it and so its time to fix it.
So, What is the easiest thing to fix for a simpleton like me (if anything) or will it be a garage job?
Post #449659 Sat Jan 24 2015 9:59pm
Disco_Mikey
If you have access to your own diagnostics, it's easy enough to diagnose yourself.
If not, then it's best left to someone else Thumbs Up
Post #449662 Sat Jan 24 2015 10:01pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Sounds like a re-calibration job, happened to me a while back, car would not stay on normal height, always stayed on extended mode, had to get it re-calibrated.
Post #449680 Sun Jan 25 2015 1:41am
Nsp1
How do I go about getting a re-calibration done?
Post #449710 Sun Jan 25 2015 12:23pm
D12TYJ
You can drop a pm to disco_mikey or bodsy on here and ask them if there able to do so if your willing to travel upto them, or try a local indie whos got the right computer to re-calibrate it.
Post #449712 Sun Jan 25 2015 12:48pm
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
Flack is located in Preston so probably the closest chap that could diagnose this for you. Drop him a PM.
Thumbs Up Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #449721 Sun Jan 25 2015 2:05pm
Nsp1
Thanks. Will make contact.
Post #449779 Sun Jan 25 2015 10:02pm
Nsp1
I've been told the problem is a rear height sensor.
I've seen them online for about £40 and I'm keen to fix things myself if I can.
Are they easy to fit? I noticed I might have to have the height re-calibrated though afterwards though.
Post #453271 Sat Feb 21 2015 1:03pm
Bodsy
Site Sponsor
Yes, easy to fit, just a couple of screws and a connector.
Yes, is likely to need calibrating. Thumbs Up
Whereabouts in Manchester are you? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #453278 Sat Feb 21 2015 1:58pm
