| RRSPORT.CO.UK | ||
|  | Home > General > Rasping/Bearing type noise when letting off the accelerator |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Front diff. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sat Jan 24 2015 8:09pm |
| ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27      | My Auto Transmission specialist suggested that it might be the front diff causing this noise after he fitted the torque converter which didn't fix it, so i removed the front prop & it still made this noise whilst driving at only 3 mph across my driveway, so it cant be the front diff.
|  Sat Jan 24 2015 8:35pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Beg to differ. Front diff will growl prop or not. As its a known issue of paint contaminating the oil it would have been first call. Our local specialist has a rolling road so easy to identify that way. But your symptoms are identical to mine before front diff was changed. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sat Jan 24 2015 8:46pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | I believe it is a noise associated with the turbo (sounds a little like a dump valve, but not as loud, no lasts a little longer?)
|  Sat Jan 24 2015 8:47pm |
| ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27      | Yesterday I did a gearbox mega flush & whilst topping up the gearbox fluid with the engine running it made the noise. The car was not in gear & not moving so it can't be the front diff as this was not turning.
|  Sat Jan 24 2015 9:50pm |
| ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27      | Reading old posts on this forum I see this is a common problem with the TDV6.
|  Sat Jan 24 2015 10:37pm |
| Bouncer222 Member Since: 19 May 2016 Location: South Yorkshire Posts: 1      | Hi,I know it's been a while since this was posted,but did you manage to get to the bottom of the problem or is there anybody else out there who had the same issue and solved it.
|  Sat May 21 2016 3:32pm |
 Gearbox cured my noise     | ||
|  Sat May 21 2016 8:00pm |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Hi ACE 219 did you ever sort this problem? I have a similar issue with my 2005 RRS
|  Mon Sep 18 2017 5:10pm |
| Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81      | Don't look any further than transfer box | ||
|  Tue Sep 19 2017 5:04am |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Is there a way to identify if it's defiantly the transfer box? I guess an oil change will be my best bet? Is that a straight forward job? Although the car is 12 years old it's only done 90k seems low milwage for a component like that to fail? | ||
|  Tue Sep 19 2017 8:50am |
| Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81      | Mine had only 94k on it
|  Tue Sep 19 2017 10:21am |
| Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81      | Could check oil wouldn't hurt
|  Tue Sep 19 2017 10:25am |
| Posting Rules
