![]() | Home > In Car Electronics > Ligth problem |
Nilsen990 Member Since: 19 Jan 2015 Location: Melsomvik Posts: 2 ![]() ![]() ![]() |
There are two fuse boxes on the RRS. The first one i would check is in the lower glove box compartment. Open it, then you will see two runners one either side to support the glove box once opened, force those runners in towards the glove box and lower the glove box further. You will then see the fuse box behind it. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
I'd be surprised if the lights have a separate fuse to that of the control they are lighting. 2012 SDV6 - it's missing a couple of cylinders
