Home > In Car Electronics > Meanwhile in Belgium
Thesurveyor
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Strange first post I will grant you.
Thoroughly enjoying my MY12 and getting used to its little ways.
However I use the sat nav. a lot and I have found that the last two mornings I have gone to input a post code only to discover that the machine thinks I have moved to Belgium (I'm in Kent!). I need to go to the address entry instead then change the country and then it all works OK.
I reset the defaults but it happened again, am I missing something?
I did set my "home" as my home post code so it presumably knows that I call GBR "home"?
Post #449088 Tue Jan 20 2015 1:13pm
Bodsy
Site Sponsor
Have you had a particularly low battery. It resets to Belgium as default, on the older systems when you put a new disk in that updated the satnav systems it would always do this.
I suspect that when you start the engine, it drains the power enough to just reset the vehicle Ecu's.
Under warranty though, I'd be wanting them to investigate further.
Check the battery connections as well. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #449089 Tue Jan 20 2015 1:29pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
Come on Belgium!
Post #449220 Wed Jan 21 2015 11:51am
