Home > Maintenance & Modifications > independant near Gatwick
triplemmm
As per the subject, can anyone personally recommend a good indy for servicing within reasonable distance from Gatwick area?
thanks
Post #447966 Fri Jan 09 2015 6:39pm
rumz
Hi mate,
Das Landrover in Horley is pretty good. I've recently done by servicing and cam belt change there.
Post #448000 Fri Jan 09 2015 10:36pm
triplemmm
cheers Rumz, although I remember reading that when you had your service you had low coolant warning and problem with handbrake. What was the outcome of that?
I have a local guy I've used for years with other cars and he's sound. But just wanted to try a LR indy as hopefully they'd be more specialised for this beast
Post #448140 Sun Jan 11 2015 6:55pm
a13xbb
I use RCV in Tonbridge which isn't too far from you, they can provide a courtesy car for £10 a day which makes getting back easier!
Post #448154 Sun Jan 11 2015 8:10pm
triplemmm
Sounds good. Will look into that too. cheers Alex
Post #448181 Sun Jan 11 2015 10:52pm
rumz
Hi mate.
Sorry for the delay.
There were error messages for the coolant and the brake but the brake message disappeared and the coolant was resolved with a top up and bleeding.
Seems like there are no other issues with it (apart from my intermittent rear pdc!)
There is also Millenium (near Costco) and another in Wallington (sorry dont known the name for that one)
Post #448410 Wed Jan 14 2015 11:22am
triplemmm
cheers rumz
Post #448426 Wed Jan 14 2015 1:17pm
