Home > Technical > Parking break
Goreskin65
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Parking break
Hello guys, I need you advice I got the dreaded parking brake stuck on but turned ignition off for a few seconds and back on to release it and parked it in P only is it ok to drive or will I cause damage to the shoes if I do drive it? Please any advice until I can get it to a garage Monday ?
Post #448120 Sun Jan 11 2015 2:33pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Now sometimes if you put into drive or reverse and accelerate a little it sometimes can release however, you'll know if it will all not, doesn't need a lot of revs.
If that doesn't work then you'll have to remove the gear nob by twisting one way and then pulling up hard. Watch your face it will hurt Smile. Once thats off you can squeeze the plastic surround that goes around the gear stick and that will pull up and unclip. Thats the hard bit and will take a lott of squeezing and a bit of force.
Once you've got that off you'll see a metal wire loop, you'll need to get some string to wrap round tk give yourself a bit of leverage and then pull that up hard, that should release your parking brake.
Hope that helps. Not sure if someones done a how to on here with pictures but that may help.
Post #448127 Sun Jan 11 2015 3:45pm
Goreskin65
Thank you for that.
Post #448128 Sun Jan 11 2015 3:48pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Here's a video showing how to release Thumbs Up
Post #448132 Sun Jan 11 2015 4:30pm
Goreskin65
Cheers chap Thumbs Up
Post #448201 Mon Jan 12 2015 6:26am
