![]() | Home > In Car Electronics > USB/MP3 playing options |
You need the Audio Connectivity Module. Around £270 from LR.
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
Once this is installed (plug and play presumably) it would perform the same as my jag one?
I don't know how your jag one worked, but mine charges my iphone (4s) and plays the music through it. When not connected, it will default to playing the USB stick.
fits in the glove box. |
Thanks for the advice. All I am interested in is playing music via USB - does it look similar to Jag one? in as much as it has a USB slot? any pictures? |
It has only one USB slot, it separately has a 30pin Apple connector which can be positioned anywhere the cable will reach to. (I have mine in the lower ashtray area (not that I have an ashtray))
Picture would be great thanks Bodsy - is this a main dealer purchase only? and is it easy to install? thanks for your time |
VPLFE0002 for D3/RRS/FL2
Thanks Bodsy for the extra info - any pics of yours would be great. Thanks |
Quick pic. Sub left and phono right. Fixed inside glove box upper. Could be fixed elsewhere if you prefer. |
Cool - thanks Bodsy its appreciated. Do you know if these can be purchased anywhere else other than Land Rover? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5126 ![]() ![]() ![]() |
Hi
Cheers Col - Ill take a look at that also plus enquire at Land Rover direct |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
Hi bodsy when the VPLFE0002 is installed can you connect a usb stick or just I pod, also can you display tracks and artwork on the cars touch screen when its connected,
