Home > Technical > Intermitent Susspension Warning light
lukestar7
Hi all,
Jumped into mr RRS 2.7 tdv6 and after driving for about 10 minutes the dreaded suspension warning lights popping up. Now if you stop, turn the car off and back on, its not there any more, it lifts and drops and holds no problem, untill you drive, and then after roughly 10 minutes it pops back up again. It still drives absolutely fine though.. I am baffled... Has anyone else had this issue or can guide me in which way to fix it?? Shocked
Your help is a vertu... Luke
Post #447952 Fri Jan 09 2015 4:59pm
panda
Hi lukestar is your compressor noisey??
mine was doing the same sort of thing.
Post #447954 Fri Jan 09 2015 5:21pm
lukestar7
Hi, no, the compressor does not seem to be noisey, although this is my first RRS and i have nothing to compare it to.
Post #447955 Fri Jan 09 2015 5:24pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
when mine started doing that it was compressor on last legs due to a leak on a rear bag Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #447976 Fri Jan 09 2015 7:32pm
Black Bess
Hello Luke
I had a similar problem (described elsewhere on here) and it turned out to be the brake light switch at fault. Can you assess whether the warning lights come on as you press the brake pedal?
It was a cheap and easy fix to what seemed a worrying problem. Might be worth a try.
Adam..
Post #448220 Mon Jan 12 2015 10:21am
Kensta
+1 for the brake light switch I've had that too, also the rear upper tailgate switch brakes down and gives same
Warning faults on dash I've had that too and it's also a cheap easy fix.
Do you get HDC error on your centre screen? Java black 2006
Post #448221 Mon Jan 12 2015 10:25am
