| RRSPORT.CO.UK | ||
|  | Home > Technical > 2005 2.7 TDV6 wont start |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Check for fuel at the bleed point at the back of the engine bay. If there is a good flow if fuel there, it could be glow plug related | ||
|  Tue Dec 30 2014 4:28pm |
| chi Member Since: 15 May 2010 Location: hampshire Posts: 49    | Thanks Disco_mikey.
|  Tue Dec 30 2014 5:32pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Right in the middle of the "V", just behind the rear of the engine cover. Should have a grey plastic screw on cap | ||
|  Tue Dec 30 2014 6:36pm |
| chi Member Since: 15 May 2010 Location: hampshire Posts: 49    | Cheers Disco_Mikey | ||
|  Tue Dec 30 2014 6:40pm |
| hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63      |
 mine didn't want to start this morning either just cranked and cranked but was kicking out smoke while cranking , put a jump pack on it and it started ? | ||
|  Tue Dec 30 2014 8:31pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Signs of a weak battery, or non-functioning glow plugs... | ||
|  Tue Dec 30 2014 8:33pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Fuel bleed point:
|  Tue Dec 30 2014 8:43pm |
 -2 this morning covered in frost tdv6 didn't want to start just cranking and diesel smoke from exhaust , checked battery only showing 11.5 volts , is this my problem | ||
|  Sun Jan 04 2015 2:29pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Low voltage definitely won't be helping. It spins over much slower with a discharged battery, and so doesn't build as much temperature inside the cylinders for combustion   | ||
|  Sun Jan 04 2015 7:37pm |
| Posting Rules
