![]() | Home > Technical > Passenger side rear brake light not working |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Try another bulb in its place first. Very common for brake bulbs to fail |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 ![]() ![]() ![]() |
Cheers Mikey ill give that a try and report back, I'll use the brake bulb from the opposite side as a test, I swapped it for an old Discovery bog standard bulb which didn't work, went for the easy option |
Swapped the brake bulbs around and the passenger side still doesn't work |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Can you swap the clusters side for side to see if the problem is up range or down range? |
Yeah I can give that a try and will report back, cheers |
Had some work done recently on the same side, seized rear calliper, is that just a coincidence? |
Bought brand new replacement bulbs, swapped out both sides and made no difference, any ideas where the fault is? |
Hate to admit it but I was changing the wrong bulb |
Sorted by sanding the connections on the new bulbs to ensure a better fitment |
I think you'll find that you had fitted bulb the wrong way round which is why it was difficult to fit, also explained the dim brake light, no doubt you had a very bright side light |
