| RRSPORT.CO.UK | ||
|  | Home > General > Vibration on start up. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Sounds like a misfire at cold which points to a weak heater plug.   | ||
|  Tue Dec 30 2014 10:36pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Thanks Simple - Would this be covered under warranty ?   | ||
|  Tue Dec 30 2014 10:38pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | According to warranty - no   | ||
|  Tue Dec 30 2014 10:45pm |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216    | I had this in Jan/Feb and on a couple of occasions the car refused to start, brake pedal became rock hard. When it did start, it vibrated a bit but was fine on subsequent starts of the same day, just as you described. Mrs. called LR Assist the first morning it didn't start and the guy forced the brake pedal down enough to be able to start it. He suggested we do the same if the problem reoccurs ( it was beyond her strength though  | ||
|  Tue Dec 30 2014 11:33pm |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | PEACHY
|  Wed Dec 31 2014 8:56am |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Thanks for all the replies gents   | ||
|  Wed Dec 31 2014 9:34am |
| Posting Rules
 it's fine after that no issues or vibrations on restart.
 ). Next time it happened to me and I was able to start by pressing brake pedal really hard but was convinced it wasn't normal. Plugged in my IIDTool to find a problem with glow plug control module (so same area as simple1 suggested). First instance of the fault was recorded at < 300km old i.e. way before I bought the car. Called LR Assist again, he acknowledged the problem, car booked, glow plug control module replaced under warranty and no starting problems since then (even in much colder than UK weather).
