Home > Technical > Brake Pad Warning Light
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
Fitted new front brake pads (Brembo) a few weeks ago, now the brake pad warning light is coming on every now and then! I fitted a new sensor wire the last time I changed the front pads, will I have to do it again……. when the warning light comes on is it the same colour for front and back?
nearly forgot Merry Christmas to all About to get into a sport
Post #446420 Fri Dec 26 2014 9:20am
Camelrock
It's the same warning light for front and rear, so check the rears, it's also worth checking your fluid level. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #446422 Fri Dec 26 2014 9:25am
Simon58
Thanks Camelrock will have a look if I can sneak out today Very Happy About to get into a sport
Post #446423 Fri Dec 26 2014 9:55am
Simon58
so had a look at the rear pads today they are like new, so now a little stumped to why the 'check brake pads' alert comes on now and again, does that mean because the front pads warning touched you have to change the sensor wire too! About to get into a sport
Post #446751 Tue Dec 30 2014 1:33pm
Disco_Mikey
If the sensor has worn down until the light has come on, it will need replaced.
Seen quite a few where the sensor has fallen out the pad, fouled the wheel and damaged the wiring, also bringing the light on
Sensors are not expensive, so may be worthwhile replacing them as matter of course Thumbs Up
Post #446752 Tue Dec 30 2014 1:56pm
Simon58
thanks DM will change it About to get into a sport
Post #446801 Tue Dec 30 2014 7:34pm
Simon58
change and all good as always thanks for the advice DM About to get into a sport
Post #447186 Fri Jan 02 2015 6:56pm
Disco_Mikey
Post #447197 Fri Jan 02 2015 8:54pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Hi, just bringing back this thread.
I had the warning light coming occassionly, but I knew that the pads were fairly good.
But it started to increase so took off the right rear to have a look. Pads seemed less than half worn,but sensor and wiring were not in place and floating around. (Ha found the problem??)
Its due to go in for a service so as a temporary fix,I got the sensor and wire and taped them up with electrical tape securely out of the way.
Now the light stays on all the time. Why Question What have I done? Any Idea ??? 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #494450 Tue Apr 26 2016 9:00am
Lost for Words
The connection must be broken, so you need a new sensor, or you can chop it and short the wires as a temporary measure to put the light out. Thumbs Up Visiting from DISCO3.CO.UK
Post #494454 Tue Apr 26 2016 10:12am
CRACKA
Thanks Lost for Words.
But I thought that the way the sensor works is when the Pads are worn it makes contact with the disc rotor to make the earth connection ? & turn on the light.
If I understand what your saying is that the sensor just completes an earth? circuit. Because mines been floating around it might be damaged and completing the circuit.?? 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #494534 Wed Apr 27 2016 1:07am
Lost for Words
No, it works the other way round. The circuit is normally closed and, when the sensor wears through, it's broken. Thumbs Up Visiting from DISCO3.CO.UK
Post #494539 Wed Apr 27 2016 8:55am
CRACKA
Okay,
Thanks for that Lost for Words. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #494643 Thu Apr 28 2016 8:39am
CRACKA
Just to let everyone know I put in new rear pads today. It was the sensor wire that was broken.
It must have happened when it came out of its slot and was floating around. The old pads were only half worn.
Interesting there is only a sensor on the right rear, no provision on the left.
It makes sense Rolling Eyes as wear is usually even on both sides at the back. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
Post #504654 Tue Sep 06 2016 12:01pm
Only one sensor at the front too. Opposite corner.
Post #504656 Tue Sep 06 2016 12:06pm
