![]() | Home > General > Frozen Electric Mirrors = Stopped Working! |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442
Evening!
Yeah, tried that. You can feel that its trying to grip, but doesn't, so I'm presuming the teeth have worn.
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
You can get go the screws behind the tweeter, I can't remember if you need to take door panel off to get to the electrical plug but I'm sure one of our grown ups will be along shortly to remind us. Have no idea what the part number is but there are bound to be on eBay. Disco and Sport mirrors are the same 2x TDV6. SE and HSE. Both returned to sender with issues👀
| ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698
It is easier to remove the door panel as you will not be able to remove the tweeter speaker assembly With out breaking the plastic lugs.it is only held on with 2 plastic lugs and 2 very thin plastic legs which are housed behind the door card. To remove the screws you will be better to remove the door card. Once this has been done you can remove the mirror. The mirror can actually be stripped down easily once you remove the mirror housing cover ( outer colour coded part ) you will see the electric motor wiring etc. |
Cheers,
| peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585
You could try squirting WD40 in the general direction of the mechanism before stripping it down. Worked for me when I had a Disco 4 with one mirror not opening. |
Mirrors miraculously started working!!!
It's because it's milder...the slight lubrication will be more fluidic. |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212
neither of mine fold in should they do its a 55 plate hse did they have them fitted or was it an extra option ?
| UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149
If it's a 55 plate it will have to be done manually via pressing the mirror adjuster down when it's set in the middle position.
thanks uk guy but it doesn't work pushing it down that's why I was wondering if it had electric fold in mirrors ? if so they must be broke |
Mmmm.... If it's a HSE it should have. It may be a fuse blown.
yes they push in easily what fuse would I look for ? |
Not sure.... Maybe someone with a manual can advise RRS HSE with a few extras & a
| All times are GMT |
