Home > Maintenance & Modifications > Ready for the cold
Camelrock
Ready for the cold
Finally got round to fitting the pre heater controller so will hopefully go out to nice warm car during the winter. It's Bellauto's latest one that you can turn on the the L/R button on the remote.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #446042 Sun Dec 21 2014 11:40pm
simple1
Now why didn't LR do that. Instead I have to have a separate remote which bangs on dash when key in ignition 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446055 Mon Dec 22 2014 9:32am
I've got one of the controllers with the wire to allow the use of the L/R button but have only installed it to use the plip remote. Where do you run the additional wire to? I spoke to Pete and he mentioned something to do with the lights but as I was expecting to use the plip remote I didn't get any details from him at the time.
Have to say that the BAS controller is a nice easy install; ironically, since I fitted it, the weather hasn't been that cold...! 2012 SDV6 - it's missing a couple of cylinders
Post #446058 Mon Dec 22 2014 11:12am
Camelrock
Run it down to the headlight and connect to the wire that goes to pin 11 on the headlight connector its the same colour as the wire from the controller blue/pink I think. Then programme the remote to operate the headlight curtesy delay 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #446060 Mon Dec 22 2014 11:19am
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
where do you fix the controller box and where do you connect the battery wire ?
any pictures any one Thumbs Up
Post #446793 Tue Dec 30 2014 6:47pm
My controller box just sits in the battery box between the battery and the box wall. The positive wire connects to the battery wire that connects to the megafuse. The earth is just on one of the body earth studs next to the heater.
Here is a picture from a Disco3 user's (Robbie) installation:
Mine is the same but has the controller in front of the BJB rather than the battery itself. 2012 SDV6 - it's missing a couple of cylinders
Post #446827 Tue Dec 30 2014 10:33pm
dazzerboy
did you all use a 1volt inline fuse to fit this ?
Post #446886 Wed Dec 31 2014 2:13pm
Camelrock
Yes fitted an inline fuse with 1amp fuse, you have to use a glass fuse and holder as the spade fuses only go down to 2amp. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #446901 Wed Dec 31 2014 3:51pm
dazzerboy
just been informed that you don't realy need a fuse as the box is so close to the battery Surprised
Post #446907 Wed Dec 31 2014 5:38pm
J.blase
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Pre heater controler
Just fitted mine took 1/2 hour very straight forward. What temp dose it have to go down to before it works thanks john. Ps thanks bas autos.
Post #446913 Wed Dec 31 2014 5:58pm
Camelrock
you need a fuse, it's an electrical circuit, it makes no difference where the component is located.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #446915 Wed Dec 31 2014 6:05pm
Hmm, I just followed the instructions that came with it. No mention of fuses being required, what rating, where they should go or how. Just a pair of ring connectors for the +ve and earth connections. 2012 SDV6 - it's missing a couple of cylinders
Post #446947 Wed Dec 31 2014 10:06pm
Camelrock
If you go onto Bellauto's web site you find the fitting instructions there including the info about the fuse.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #446962 Thu Jan 01 2015 12:19am
Must have missed that Embarassed . Seems a bit odd not supplying a fuse / fuse holder in the wiring if it's required.
That means I shall have to source and fit a fuse now... 2012 SDV6 - it's missing a couple of cylinders
Post #446965 Thu Jan 01 2015 12:29am
Camelrock
I thought the same it just says fit 1amp fuse (not supplied).. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #446968 Thu Jan 01 2015 12:33am
