![]() | Home > Technical > Little Switch / Button |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Not OEM - DIY fit for an alarm or immobiliser?? Have you had the cover off are they connected to anything?? |
RRSMike Member Since: 01 Oct 2014 Location: Fife Posts: 32 ![]() ![]() ![]() |
Ahh, that will be why I can't find anything for them then. Only just noticed them the other day so not had a chance to have a look underneath. |
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Ejector Seat!?? |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Seen something similar in another car, a toggle switch to cut power to fuel pump but not the other button. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
I've seen switches for turning on/off an aftermarket rear entertainment system. Bottom line is it could be hooked up to anything, the only way to find out is to trace the wiring back to source. |
Somerset Bumpkin Member Since: 12 Dec 2012 Location: Swindon Posts: 74 ![]() ![]() |
I knew someone who had a similar switch for switching the speedo off and saving a few miles.. |
Spoke to the garage I bought the car from and apparrently these are for a scrambler which the previous owner had installed on the car. |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
whats a scrambler? |
I believe its some sort of device that apparently makes you invisible to police radar/camera vans by jamming the signal so they cannot tell your speed? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4509 ![]() ![]() ![]() |
Are you brave enough to try it? |
thanks mike |
