![]() | Home > General > Stealers, Ahhhhhhhhhhhhhhhh!!!!! |
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
Is this a main stealer? if it is you need to find an honest independent ? |
| KJP Member Since: 13 Dec 2011 Location: St.Albans Posts: 9
Yes it is a "Main Dealer"
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Always happened on mine - I leaned on it to make the connection ( tailgate close ) & then use the keyfob to lock & unlock - issue fixed |
Just got it back and spent about 5 min's trying to get it to shut (or open) but no joy.
Ok so the indy said that they could look at it but would advise that they too might have to damage the rear panel.
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Stealers are good at doing it the longest way round = most expensive. I only get a dealer to service the car to keep its history, learnt the hard way that anything else can be done better by myself. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297
All thinger's and fumbs no doubt 2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone 2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone 2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone |
| JKay Member Since: 17 Nov 2010 Location: NSW Posts: 127
So what was the initial bill of £1,200 for if it didn't even address what you sent it in for in the first place? |
New Battery @ £325, old battery was tested as been ok, they just advise it needed changing!!!!!
Pads are easy enough to do yourself (see my link in my sig) and battery can be had cheaper than that, even for the LR gel battery (which is the best really). |
| TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96
Find an independent that uses LR or OEM parts.
Ah stealers Huh. I got a new battery from Mercedes when I sent my E Class in and it cost 4 and a half times more than any other high end battery available anywhere else. When I queried them as to why it was so Expensive they said the current it releases is suitable for only MB vehicles. Needless to say I won't be getting any more batteries through my dealer .... |
