Home > Other Site Sponsors > RRS Software Updates for older spec to MY08 spec from Bodsy
Page 8 of 15 <123 ... 789 ... 131415>
Bodsy
Site Sponsor
PM sent. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #444287 Wed Dec 03 2014 9:11pm
Ravmann
Checked my pm's and none showing, could it be because I haven posted enough?
Is it ok to put my email address here instead?
Thanks
Post #444289 Wed Dec 03 2014 9:19pm
Ravmann
I've got the pm now, will be in touch over the next couple of days.
Thanks
Post #444290 Wed Dec 03 2014 9:23pm
rumz
I am interested in this but live near Gatwick Airport Sad
Post #445322 Mon Dec 15 2014 1:11am
Bodsy
Site Sponsor
Runs, you may be in luck as I'm down that way soon.
I'll drop you a PM later. Thumbs Up Bodsys Brake Bible
See it HERE
Post #445328 Mon Dec 15 2014 7:41am
rumz
Perfect Bodsy,
Look forward to the updates - can anyone reprogramme the key fob to unlock all doors etc?
Post #445342 Mon Dec 15 2014 10:35am
Bodsy
Site Sponsor
I thought that was just turning off in the settings using the indicator stalk and steering wheel buttons.
Cant remember what it's called off the top of my head. Bodsys Brake Bible
See it HERE
Post #445355 Mon Dec 15 2014 1:21pm
Disco_Mikey
rumz wrote:
Perfect Bodsy,
Press and hold the lock and unlock buttons together for 3-4 seconds. If successful, the horn will sounds, and the key will unlock all doors on the first press Thumbs Up
Lazy entry, Ian Thumbs Up
Post #445410 Mon Dec 15 2014 9:09pm
rumz
Perfect - it worked.
Thanks Smile
Post #445536 Tue Dec 16 2014 5:35pm
Unclebuck
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Re: RRS Software Updates for older spec to MY08 spec from Bo
Bodsy wrote:
Hi All,
Thought I'd start a new thread with pictures to show the software updates that are of most interest to Pre MY07 RRS Owners.
This should be familiar to you, its the Standard Dashboard
Clock On The Dashboard/Lights On indicator
After Clock On The Dash is ENABLED - LOOK a Clock you can see! (Why LR didnt do this in the first place I have no idea.....)
This is shown with the Lights switched OFF
And a close up. As you can see, the "Lights On" indicator is in fact the old (No longer used) Fuel Burning Heater indicator and is pale Red.
Three Flash Indicators
Three Flash Indicators can't really be shown (other than in a vid perhaps) but it is when you tap the indicator and the indicators then flash three times and self cancel. Makes it easy work on motorways etc for changing lanes without you having to remember to switch it off
Gearbox Reset/Recalibration
This resets your adaptive gearbox back to factory values (it remembers how you drive) it will also recalibrate the Transfer box, combined together, it often results in a smoother drive and has been known to help resolve symptoms of some gearbox juddering. This is not always guaranteed as there can be many causes of this symptom, but this is certainly one of the cheaper options to try first.
Sat Nav On The Move
This is a long update (90 minutes) but is very very popular as it is incredibly frustrating to have to keep stopping to change your destination. This update allows you or your passenger Wink to make any changes to your satnav destination whilst driving. Instead of seeing the greyed out screen, you will see this....
To prove it works when driving...
Thanks to Chris for letting me take the Pictures of his updates Thumbs Up
PhoneBook over Blutooth Update
This updates your standard factory Fit RRS Blutooth module to enable you to select your phonebook contacts from the screen of your radio display. It also fixes issues with iphone etc where you have to enter the 2121 code in each time you want to connect. I can do this one by post also and its very easy to change on a RRS.
service reminder reset
This resets your service message. some independants are not able to reset your servcie indicator after they have changed oil etc. this can be reset for another year.
Read/Reset Fault Codes
Can also Read and reset All fault Codes and provide you with an e-mailed list of any that come up if needed. This could save you a more expensive trip to a dealers.
Another popular one is to purge and test the Fuel Burning Heater so that it makes sure it works ready for the winter and update other modules as needed.
If you would like any of these updates, then please feel free to PM or e-mail me. It helps if you include your postcode and model year and what updates you would like to have done. Thumbs Up
Ian
Hi Mr Bodsy, I'm a Newbie here so please be gentle ! , could you please advise the cost and how to obtain these updates ? I live in South Yorks ! 2005 RRS Supercharged Many thanks Neil
Post #448716 Sat Jan 17 2015 10:50am
Bodsy
Site Sponsor
Sure,
I've sent you a pm. Thumbs Up Bodsys Brake Bible
See it HERE
Post #448717 Sat Jan 17 2015 11:03am
magre
Italy 2006 Range Rover Sport TDV6 HSE Stornoway Grey
hi bodsy,
i wrote also in other thread and now i see this one.
can you help me for the bluetooth on an rrs my 2006 (i live in italy)?
thanks
Post #450258 Thu Jan 29 2015 6:50pm
Bodsy
Site Sponsor
Magre, yes I can, will drop you a PM.
See it HERE
Post #450271 Thu Jan 29 2015 7:32pm
magre
hi bodsy,
have you seen my mp?
thanks
greg
Post #450345 Fri Jan 30 2015 2:08pm
Bodsy
Site Sponsor
Yes, have replied Thumbs Up Bodsys Brake Bible
See it HERE
Post #450354 Fri Jan 30 2015 3:34pm
