Home > Technical > Could Battery cause this
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
The Sport has been lying off the road for a few weeks as I had bought another old 4x4 for as a runabout. I have been starting regularly but after initial start some times I would get up a message saying Special Programs off. If I had taken it out for a run the next few times starting I wouldn't get this message.
Had it out for a run yesterday and after going out to overtake someone I lost all power and drive and this same message flashed up again,coasted to a halt and then switched off and started again and all seems ok.
I have also had over the last few months the Heated front Seats working intermittently and the Radio message for Low Power Mode. Could a Battery that's not 100% cause this.
Cheers Jock
Ps the battery on the other 4x4 that I have bought is not great 66AH ,had thought about fitting the old Sport Battery if I change it which is 90AH could this cause me any problems .
Post #445038 Thu Dec 11 2014 3:19pm
Disco_Mikey
It takes hours to charge the battery when driving, so starting it would not have made much difference
The Special Programmes Off message on startup IS caused by low voltage, especially when cranking, as the starter draws anything up to 300Amps...
Seeing a lot of voltage related faults now the colder weather is here.
You need to check the alternator charge rate. If this is OK, consider fitting a new battery. Batter yof choice just now is the Exide Premium, 900CCA and 100Ah, one of the best on the market, and sub-£100
Post #445043 Thu Dec 11 2014 3:38pm
Tiny Timmy
Disco, Would that do a 4.2 S/C ??.......................TT Question
Post #445048 Thu Dec 11 2014 5:35pm
Disco_Mikey
Yes, will do all D3/RRS that dont need an AGM battery Thumbs Up
Post #445051 Thu Dec 11 2014 5:53pm
Tiny Timmy
Great thanks disco Im off to the Battery Shop Very Happy Thumbs Up
Post #445057 Thu Dec 11 2014 6:35pm
Jock 77
Re Could battery cause this
Thanks Mikey will just go with fitting a new one mate.
Have managed to source through a friend a Varta which is stamped on my Land Rover battery 110ah with 930cca for around £120. Should this suit .It is supposed to be the Varta recommended one for it.
Thanks again Jock.
Post #445072 Thu Dec 11 2014 11:55pm
