Home > Faults & Fixes > Rear glass tailgate fault
cubbyno9
Hi all,
My upper tail gate has started playing up. Open the car and tail gate clicks open, Close then 2 secs later pops open again. Close again and then clicks open....... Sometimes opens straight away other times after 5 or so secs. I can here the locking mechanism clicking on then off. Is it just the sensor or what else should I be looking for, thanks. 2017 Range Rover Sport HSE
Post #444726 Mon Dec 08 2014 10:19pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
You need a new handel / switch the soft rubber part you grab to open the upper tailgate as its full of water 15 min to change cost 30£ off eBay
There is a post some were showing you how to do it on here and YouTube
Post #444845 Tue Dec 09 2014 10:06pm
ShooterNeil
http://pages.ebay.com/link/?nav=item.view&...1261515709
Post #444846 Tue Dec 09 2014 10:09pm
cubbyno9
Hi ShooterNeil,
Thanks buddy, I appreciate your help. I will have a go at this, cheers. 2017 Range Rover Sport HSE
Post #445250 Sat Dec 13 2014 10:03pm
Disco_Mikey
Part number you need is YUZ500020
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
Takes 30 seconds to fit. Lever the old switch out (doesn't matter if it breaks) follow the wiring back to the connector, unplug and replace Thumbs Up
Post #445251 Sat Dec 13 2014 10:09pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: Rear glass tailgate fault
cubbyno9 wrote:
Hi all,
It is the release handle under number plate shroud,behind rubber cover. The alloy hinge type thing that pushes the micro switch gets corroded and sticks. If you clean this part and give it a good dose of WD40 it will be fine. I did mine 2 years ago and it is still fine. Otther option is a new complete switch about £25/£30 and easy t do. itisme
Post #445267 Sun Dec 14 2014 10:25am
cubbyno9
Hi Mikey and Harry, I am back from offshore this week so will have a go at the good old WD40 first. 2017 Range Rover Sport HSE
Post #445305 Sun Dec 14 2014 7:29pm
Disco_Mikey
If that doesn't work, I keep a switch in the back of the car Thumbs Up
Post #445307 Sun Dec 14 2014 7:45pm
harrygh60
Tailgate Switch
Hi Mikey I see by your link there is a switch on Ebay for £19.99 Free Pstage From Islelandrover Doncaster. I have used them before when my LED Rearlight Cluster was stolen. They are very cheap £178 for the light,was delivered next day Thumbs Up Thumbs Up itisme
Post #445333 Mon Dec 15 2014 9:19am
cubbyno9
Thanks Mikey, cool I will catch up with you when I get back, cheers 2017 Range Rover Sport HSE
Post #445391 Mon Dec 15 2014 6:09pm
