Home > Technical > Engine System Fault
crozzo
England 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Engine System Fault
Hi all
got Engine System Fault showing.
Could someone please explain how to free up the Turbo actuator rods and where to find
2.7 HSE 2007 sport
Post #433765 Wed Aug 20 2014 11:40am
bigdavy60
2005 Range Rover Sport TDV6 HSE Java Black
ive had a look on mine which seems to have the same fault , dont see these actuator rods tho ?, keep me posted if you find out where they are please
Post #433772 Wed Aug 20 2014 1:47pm
crozzo
Have just sorted mine out with great success.
It is located on the passenger side of the car. I had to remove the wheel and the heat shields. The turbo and actuator are clearly visible when this is done. I sprayed it with silicone grease and moved it a few times with a hooked screwdriver. After a few times it became easy to move. Started the engine and it started to move on its own. Heat shields and wheel back on and code reader in. Car started and no codes and ESF on display gone
Post #433792 Wed Aug 20 2014 5:45pm
bigdavy60
so is there only 1 turbo on the rrs at the n/s ? , i have been under the impression there were 2 ?
Post #433824 Wed Aug 20 2014 11:00pm
crozzo
On mine there is only one turbo.
I have the TDV6 HSE 2.7 year 2007
Hope this helps.
You can see a round topped slider at the side of the turbo
Post #433848 Thu Aug 21 2014 9:06am
bigdavy60
hi my rrs is a 2005 2.7 diesel , have taken n/s wheel off and 1 small heat shield at top 3 x 10 mm nuts , i dont see any actuator rod so far is there anything else that needs to be removed ? cheers
Post #433889 Thu Aug 21 2014 3:10pm
crozzo
Hi mate. When I removed the small heat shields on mine, you can see the side of the turbo. There is a flat plate running across the top of the actuator. The actuator has a round ball on top. This is the piece that I moved back and forth to free it up and squirted plenty of silicone spray on it
The picture i have attached is a photo of the area. The actuator is just behind the bits you see in picture
Post #433890 Thu Aug 21 2014 3:20pm
bigdavy60
horray at last ive found it cheers Thumbs Up , given it a good spray with wd 40 but off to work now so ill get back to it later it seems locked solid ! , which direction does it move up and down or ?
Post #433891 Thu Aug 21 2014 3:40pm
bigdavy60
ooops forgot to update this post , turbo actuator freed off and both egr valves blanked , now running very well all trouble codes gone , delighted with the result Thumbs Up
Post #444559 Sun Dec 07 2014 1:11pm
Camelrock
2.7 TDV6 have 1 turbo, 3.6 TDV8 have 2. 3.0 V6 have 2 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #444571 Sun Dec 07 2014 6:11pm
bigdavy60
surprise surprise i even managed to help a fellow owner sort out his turbo actuator on his 2.7 lmfao Rolling with laughter
Post #444798 Tue Dec 09 2014 4:36pm
