![]() | Home > General > Sunroof drain help! |
Cheap net curtain wire, rod that gently down the hole from the sunroof. |
| a13xbb Member Since: 07 Mar 2013 Location: Kent Posts: 121
Cheers I'll try that tomorrow!
| ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49
Have you checked where it comes out as well? If you remove the grill in the wing,pull back the rubber cover you will see a sort of pinched pipe - that is where the water runs out. Try and open this up and dirt often blocks in there. |
Yeah sadly your talking about the drivers side which is easier to get to as drain outlet is behind the vent on the wing, passenger side is more hidden!
| All times are GMT |
