Home > Technical > Lumpy Idle On Start-Up
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Had a look using the search facility, and a few of them point towards EGR valves or Air Flow Sensors, but ive blanked the AGR's and have a new sensor.
The car on start-up, for the first few minutes is very lumpy when ticking over when I'm stationary (stuck in traffic). The car idles at just above 750rpm, and I can see the rev counter rising to about 850, then dropping back down again repeatedly. You can also physically feel the car ticking over during this period, as of the engine is rocking with the idling, not massively, but enough that you know it shouldn't be doing it!
The car drives fine during this initial period, its just when ticking over in traffic. Once warm the car drives great and idles fine.
Only seems to have started in the last few weeks with the weather getting colder.
Help & suggestions appreciated!! Thumbs Up 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #444374 Thu Dec 04 2014 7:01pm
SRE
Spain
Throttle body seal / Air flow meter seal, I only say this since I thought you had just had a replacement. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444376 Thu Dec 04 2014 7:16pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Unfortunately that sounds as tho is could be a fuel injector on its way, they are more noticable when cold.
I would get the return flow checked and a quantity comparison done.
If it is an injector, I would try a dae engine treatment, Google it it may link to my website.
I have used many at work and even on my own Rrs. If manged to bring one of my Injectors back from the dead. And also on many of our customers cars. The only time it dose t work is if the injector is contaminated with metal from the pump.
If you require any further info drop me a pm.
Post #444380 Thu Dec 04 2014 7:44pm
darrenmcneill
Hmmmmm...... This doesnt sound like its going to be cheap...??
Im presuming this would throw up a fault code? 2006 HSE for Sale - £7,499 (Manchester)
Post #444382 Thu Dec 04 2014 8:16pm
rich_sargie
affraid not, they only really show fault codes when the electronics go bad or the smooth running evaluation maxes out.
Injector contamination is comman fault on all tdv6's.
Like I say it may not be to bad we have had a few tdv6's with similar faults and have some really good results with the fuel treatment.
You have got nothing to lose.
Always worth getting it checked by some one local who knows what they are doing tho just in case we are barking up the wrong tree.
Post #444385 Thu Dec 04 2014 8:49pm
SRE
Spain
Darren
pM sent In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444387 Thu Dec 04 2014 8:51pm
SRE
Spain
Check temp sensors, including oil temp sensor.
Clean MAP sensor, do NOT poke anything inside it, just wash it out with WD40 etc
Could be crappy fuel, whip fuel filter off and check it it has any water in it. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444388 Thu Dec 04 2014 9:00pm
darrenmcneill
Cheers for the advice and the PM's....
Could really do with not having to spend oodles of cash just before Christmas, the daughters birthday, g/f's birthday, Christmas spend and yesterday's VERY expensive engagement ring has meant funds arent as boyant as they were a month ago!! lol...
to be young and single again! 2006 HSE for Sale - £7,499 (Manchester)
Post #444396 Thu Dec 04 2014 10:04pm
SRE
Spain
Darren
If you are unable to sort the issue yourself, then it may be worth getting hold of Mick (Flack on these Forums) he is based in Preston, so not that far from you. Anyway no harm in sending him a PM In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444425 Fri Dec 05 2014 9:51am
darrenmcneill
Car was fine yesterday, and it was a cold start.
Its looking in the minus this morning out there, just going to get ready for work then head out, so il see if this cold snap has any effect on the car this morning. 2006 HSE for Sale - £7,499 (Manchester)
Post #444482 Sat Dec 06 2014 9:50am
